Go to Post Real projects have good and bad aspects, problems that must be dealt with, and lots of things that dont make any sense from your side of the fence. - KenWittlief [more]
Unread 07-01-2017, 19:25
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to beholdRoboshant is a splendid one to behold
Terminal Velocity of the Fuel Balls
Does anyone have any estimates for the terminal velocity of the fuel balls?
Thank you,
Dikshant Sharma
Unread 07-01-2017, 19:43
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: Terminal Velocity of the Fuel Balls
Thank you,
Dikshant Sharma
*Mumbles something about an unladen swallow*
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 07-01-2017, 19:50
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Terminal velocity is the highest velocity attainable by an object as it falls through a fluid (air is the most common example, but the concept applies equally to any fluid)
With that definition, and with G23:
Shoot FUEL from your own LAUNCHPAD. A ROBOT may only LAUNCH FUEL while in their LAUNCHPAD (i.e. at least breaking the plane of the line with BUMPERS).
I don't see any teams actually approaching terminal velocity with their fuel. So, why do you want to figure out what it is? trying to shoot the ball through the ceiling of your venue?
2016: Lake Superior WFFA
Unread 07-01-2017, 21:00
Roboshant's Avatar
FRC #0226
Rookie Year: 2015
No, trying to calculate ball trajectory.
Unread 07-01-2017, 21:34
Terminal velocity is a simple way of incorporating air drag force into trajectory calculations.
At terminal velocity, the force of air drag is equal to the force of gravity.
If you assume air drag is proportional to velocity squared, you can then compute the air drag force at any velocity.
You can then set up an Initial Value Problem and numerically integrate it to find the trajectory.
Unread 07-01-2017, 21:43
Like this.
Unread 07-01-2017, 22:36
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
*Mumbles something about empirically determining terminal velocity of balls by firing them out of a bench grinder*
Unread 08-01-2017, 00:45
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
In our team's unscientific testing of the fuel ballistics behavior (i.e..no one was writing anything down), we observed that they are pretty stable when tossed but they lose velocity rapidly and eventually just want to drop out of the air.
Dimples on golf balls are not the same as holes in a hollow ball.
Jim Browne, EIT
Team 1058 - PVC Pirates
Unread 08-01-2017, 02:15
AMendenhall AMendenhall is offline
FRC #3925
AMendenhall is an unknown quantity at this point
I don't think aerodynamics will be useful for modelling flight paths of fuel; the holes will let air through, and even if the interaction is significant, it wouldn't be practical to model internal air flow.
Sidenote: I know one of the pieces of software in the KoP vouchers does airflow modelling, that might be worth looking into. Also Wolfram Alpha Pro: Amazing.
But...
Here I'll link my projectile motion with air resistance desmos graph. I used it last year with the solid balls. It assumes that friction is proportional to velocity directly (ie not squared) which is technically an incorrect assumption, but it looks pretty.
Unread 08-01-2017, 08:51
You don't need to model airflow in order to build a useful simulation. All you need is some good data.
For any team so inclined, here is an opportunity to provide a useful service to the community
Place the cannon against a block wall (a gym perhaps) and fire shots along the wall at different elevation angles and muzzle speeds while taking high-speed timestamped videos. Make sure there are no running fans or open doors or windows (to eliminate air currents).
The blocks act as a Cartesian grid for marking 2D (x,y) location.
Using the location vs time data, that data can be fit to a parameterized model to find values for the model parameters which provide the best fit.
Once the best-fit parameters have been experimentally determined, the model can be used by teams to help design their cannons.
I'll volunteer to do the model fitting if the data is made available.
[EDIT] Thinking back to my boyhood, I seem to recall that Wiffle balls exhibit a profound Magnus effect. Topspin and backspin can dramatically affect the flight path. This makes the data collection and modeling quite a bit more difficult and contentious.
Unread 08-01-2017, 14:05
AcidWombat AcidWombat is offline
FRC #0971
AcidWombat is an unknown quantity at this point
I think the more pressing question is the maximum fire rate of the balls before they start colliding with each other at the apex of their arc.
Unread 08-01-2017, 19:15
Dan Waxman Dan Waxman is offline
FRC #0263 (Aftershock)
Rookie Year: 2016
Dan Waxman is an unknown quantity at this point
I wonder if that's because of the holes in general or the fact that wiffle balls only have holes on one side. With holes more evenly spaced, it might make a difference, though I'm not entirely sure.
Unread 08-01-2017, 19:21
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We did specific testing to see if spin affected ball trajectory on the order of what a wiffle ball does, and these balls are not affected in the same way as wiffle balls.
I opine that the uniform distribution of holes does not enable the very interesting aerodynamic effects that make wiffle balls so darn wiffly.
For reference.
Unread 10-01-2017, 20:05
17gecklerm 17gecklerm is offline
FRC #4926
17gecklerm is a glorious beacon of light17gecklerm is a glorious beacon of light17gecklerm is a glorious beacon of light17gecklerm is a glorious beacon of light17gecklerm is a glorious beacon of light17gecklerm is a glorious beacon of light
Team 4926 conducted a ball drop experiment to measure the terminal velocity of the fuel balls. We confirm a terminal velocity of 10.16 m/s (33 ft/s). From this we calculated the drag coefficient to be 0.45. Thanks Ether for the help! If you want to see our video you can find it on our Facebook Page (Columbus Robotics) or through this link.
https://www.facebook.com/Columbus-Ro...5539754895807/
Mackenzie
Unread 11-01-2017, 08:38
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Your thoughts are exactly right. REAL Wiffle balls (manufactured 1 mile from where I now sit) were specifically designed to curve, and that's why the holes are only on one side.
