Go to Post What? Thinking is required? I certainly hope not! If so, I'm toast! - Robert Cawthon [more]
Unread 08-01-2017, 00:46
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Point of reserve gear?
So I have been reading and reading and trying to understand the point of the reserve gear. If you think about it it gives both teams a free gear. This means if each alliance places it in the first slot they are still equal. Why not just get rid of the gear and make one of the other spires require one less gear. The only reasons I can see are:
-FIRST wanted higher game scores so they are giving a free 40 points.
-An alliance knows they need an extra 35 points in auto to win the match and they are unable to place a gear on the peg in auto so they take the 25 point tech foul and take the 35 points for spinning up a spire.
-FIRST wants to see the competence of human players to place the gear for the free points.
To me it seems much more logical to make the spire that takes 6 gears only need 5 and get rid of the reserve gear. This would make the game more interesting because it would require teams to place 7 gears to spin 3 spires as opposed to 6 because of the free gear. Please inform me if I am missing something in game strategy. I appreciate any help understanding it.
Unread 08-01-2017, 00:48
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: Point of reserve gear?
I believe so that it offers some more ways they can balance things out for DCMPs and FIRST Championship.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 08-01-2017, 00:51
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Because it can't be used in autonomous, it gives more incentive to be able to score at least 1 gear in auto, giving a 20 point edge.
Unread 08-01-2017, 00:59
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Situation A (team takes foul to place reserve gear in autonomous):
60 points (autonomous rotor) - 25 points (tech foul) = 35 points
Situation B (team places reserve gear in tele-op):
40 points (tele-op rotor)
40 > 35
Unread 08-01-2017, 01:11
John.Benz's Avatar
John.Benz John.Benz is offline
FRC #0093 (N.E.W. Apple Corp Robotics)
John.Benz is an unknown quantity at this point
Pretty Much.
On the note of the removal of gears the rule book states
"The number of pre-populated GEARS may change for District Championships or the FIRST Championship.
ROTOR 1 ROTOR 2 ROTOR 3 ROTOR 4
Pre-populated GEARS 0 0 1 2
PILOT placed GEARS 1 2 4 6
One GEAR, the Reserve GEAR, is staged on the AIRSHIP at the start of the MATCH at the base of the STEAM TANK, as shown in Figure 3-12."
They actually can removal some of the pre-populated gears in the FIRST Championship, but it doesn't mention removing the free gear. The free gear just acts as a place anywhere pre-populated gear.
Unread 08-01-2017, 01:19
nardavin nardavin is offline
FRC #2403 (Plasma Robotics)
nardavin is on a distinguished road
My guess would be to balance auto and teleop.
They want one robot to be able to activate the first rotor in auto, making sure that a single good robot in a quals match is not totally prevented from scoring an auto rotor. However, they want the teamwork of all 3 teams on an alliance to be able to score the second auto rotor.
However, I guess that they feel that the challenge should be easier in teleop. I guess it makes sense, as 13 gears in the 135 seconds of teleop means you only have approximately 10 seconds per gear. Removing one gear increases this time to about 11 seconds per gear. Also, it means that the score per second of the gears slows down sooner as it either completely removes the time to get the 1st rotor running or halves the time to get the 2nd rotor running. This is probably to encourage teams to try to score fuel, as the points per second of scoring fuel is (totally guesstimated) approximately equal to installing the gears for the 3rd rotor.
If I had to guess, this gear will probably be gone at the district champs and championship level (in addition to possibly removing some pre-installed gears)
In the past there is usually a rule that says disregarding rules strategically for a net point gain will escalate the penalty. However, I can't find it in this year's manual. Am I just blind or is it not there? I see that some rules (like G04) individually note that if abused for strategy the penalty will increase, but I don't see a rule that applies it to all rules.
Team 2403: Plasma Robotics
Member 2014-2017, Head Programmer 2015-2016, Leadership Team 2016-2017, Co-President 2017
Unread 08-01-2017, 01:22
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
only the prepopulated gears are subject to change. the reserve gear is not.
I just went through the book looking for the same thing and also came up empty.
Unread 08-01-2017, 01:33
John.Benz's Avatar
On page 110 it says "T03. Egregious or repeated violations of any rule or procedure is prohibited.
Violation: The Head REFEREE may assign a YELLOW CARD as a warning, or a RED CARD for DISQUALIFICATION in MATCH."
Doing that action strategically, if repeated wouldn't be allowed.
Unread 08-01-2017, 05:50
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
There will probably be a few (or many) matches where the pilot does nothing but place that gear. (And drop the rope)
1- the pilot is at least a little important in every match
2- it allows every pilot to practice with at least one gear each match.
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 08-01-2017, 06:46
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
40 > 35
True; however, this would still artificially inflate your match score (since fouls add to the other alliance's score). If done strategically against alliances you're confident you can beat by 6+ points, this could boost your team's ranking (as the second order sort after ranking points is cumulative match score).
EDIT: I don't condone this strategy (and personally hope the rules don't allow it come competition season), but as the rules are currently written I don't see much stopping it.
Unread 08-01-2017, 09:06
ATannahill ATannahill is offline
AKA: Alex Tannahill
40 > 35
The 25 are awarded to your opponent, you are still padding your match, auto and rotor points which is useful for ranking or tiebreaking (although cleaner game does go first for tiebreaking).
- Arizona North
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
T03 stops it as mentioned above. No additional clarification should be needed.
Unread 08-01-2017, 09:39
Catherine57 Catherine57 is offline
FRC #2077
Catherine57 is an unknown quantity at this point
I suspect it is for looks when you have an alliance that can't do gears. Having at least the main rotor spinning on each airship is more of an audience pleaser.
Unread 08-01-2017, 11:55
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Somehow I still think we will see at least one alliance with a score of 0 this year, when their human player drops the reserve gear in their excitement
Unread 08-01-2017, 17:59
Dibit1010 Dibit1010 is offline
FRC #0587
Dibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond repute
I'm confused- can a pilot get a gear from a bot and put it in the 1 gear slot to get the big rotor turning for auto points? I looked through the manual and didn't find anything against it but it seems odd that it would be allowed
Sent from my iPhone using Tapatalk
