Go to Post Messy wires are a pain in the chassis - [more]
Unread 07-01-2017, 17:44
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Question Lift Peg (Spring) Source?
The McMaster listing https://www.mcmaster.com/#9664k68/=15ta0ri as per the field drawing is showing "usually ships in 2 weeks" and our order confirmation says "ships in 2-4 weeks
Anyone have leads on other (more readily available) sources?
2002 -> 2006: Student, 417 (Stangbots)
2008 -> 2010: Mentor, 125 (NUTRONS)
2014 -> NOW: Mentor, 2039 (Rockford Robotics)
Unread 07-01-2017, 23:37
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Re: Lift Peg (Spring) Source?
In the same boat, been searching but can't find an alternate source. Would appreciate any help!
Unread 08-01-2017, 00:02
garpal_robotics's Avatar
garpal_robotics garpal_robotics is offline
AKA: Mark Sawyer
FRC #5920 (VIKotics)
garpal_robotics is an unknown quantity at this point
Hi folks-- ran into the same issue. I ordered the 9664K68 and will wait the 2 weeks for the real deal... However right above that spring on McMaster is: 9664K31 it is a lighter gauge wire .105 vs the .135 but it has the same outside diameter... I think it will get us through prototyping in week one. (it was available right away)
Hope that helps a little.
Unread 08-01-2017, 00:23
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Word of warning: 9664K31 won't behave anything like the official spec 9664K68. The field official spring has 24lb starting force and 159lb/in spring rate. The replacement you spec'd is a 9lb spring with only 14lb/in spring rate, nearly an order of magnitude less stiff than the competition spec.
Unread 08-01-2017, 01:03
dtengineering's Avatar
AKA: Jason Brett
Try this. They also have Canadian distribution so will ship without brokerage. http://www.essentracomponents.com/en...springs/es-241
Unread 08-01-2017, 03:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Just call McMaster. "ships in 2 weeks" tends to be the standard placeholder for "we don't have this at the moment". I've almost always had that 2 weeks go down to 1-2 days when I call and say I need it sooner.
I'm sure it's gonna be longer than 2 days in this case but I would be surprised if McMaster is actually out of stock for 2 weeks. It may just be an automated status since they got a massive run on an item they probably sell 1 or 2 of a day at most.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2017, 03:59
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Don't forget McMaster has five regional distribution centers. You might be able to pick one up if you're located near one of the warehouses.
Unfortunately I wasn't able to determine the location of all of the regional warehouses, but I do know we have one here in Kansas City.
Can't hurt to call and ask for directions to a warehouse, or rushed fulfillment.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 08-01-2017, 07:33
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
The five regional distribution centers are in Atlanta, Chicago, Cleveland, Los Angeles, and Princeton (NJ).
Also have any Israeli teams found an Israeli distributor with an equivalent spring?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 08-01-2017, 08:20
AKA: Josh Patterson
Hmmm, we definitely got McMaster parts locally (Kansas City) when I was on a team, any idea of a warehouse closed in the past couple years?
2016-Present FTAA
Unread 08-01-2017, 08:24
Ari423's Avatar
FRC #5987 (Galaxia)
No idea but those are the 5 listed on their website (top left corner)
2013: Programmer
Unread 08-01-2017, 15:18
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Greetings,
I am looking at the "team build" wood drawings. I do not see a cut length for the 7/8 diameter spring. McMaster shows the part is 36" long. I doubt we need all that. Home Depot sells a 7/8 with some ends that i would have to cut off.
Anyone see the spring length for the team build?
Thanks, Troy 2450
Unread 08-01-2017, 15:47
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
Originally Posted by TroyCDH View Post
Greetings,
Thanks, Troy 2450
Hi Troy,
The length is 9" per the team build plans. We bought a spring at Menards that is that length, but not as thick guage, therefore not as stiff. It works fine for prototyping.
Vince
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 08-01-2017, 16:22
Ubiquity Ubiquity is offline
FRC #5027
Ubiquity is an unknown quantity at this point
I found a 12 inch extension spring at Home Depot, sku 172 045 15637. Cost about $7. This is the Everbuilt (Home Depot branded) spring found near door hardware.
Looks like it will work just fine, It may be a little less stiff than the McMaster.
Available today! (I do not work or endorse Home Depot Products. )
https://drive.google.com/open?id=0B2...mNwMGxsZ3ZOVU0
Former mentor: 255(4y), 254(2y), 668(1y), 751(1y),5027
Current mentor 2854, 5905
Volunteer, Ref, Inspector, Judge, FTA
Nat. Champion 2000(255), Nat. Chairman's 2004(254), SVR Champion 2015(5027)
(Botball N. Champ 2001)
Last edited by Ubiquity : 09-01-2017 at 13:03. Reason: Include picture finished field element
Unread 08-01-2017, 16:32
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I called. They guy said, "Is this for a robot project? Yeah, we're not going to be able to get them for at least a week." [Los Angeles area center in Santa Fe Springs]
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 08-01-2017, 16:45
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
BenDSterling will become famous soon enough
I just spoke with McMaster [Atlanta Distribution Center] and they guy on the phone said that this spring is currently the most popular item on their site right now (haha go FIRST). He also said that the majority of the phone calls he has answered today have been asking for this spring. He was genuinely confused on why this spring was so popular.
He said that, if anything, it will probably be longer than expected. So we might be out of luck.
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
