Go to Post This is why I love this game. It's like high speed chess with flashing lights and lots of noise. - Karthik [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 08-01-2017, 01:20
19lmyers 19lmyers is offline
Student
AKA: Luke Myers
FRC #0980 (Thunderbots)
Team Role: Scout
Rookie Year: 2016
19lmyers has a spectacular aura about19lmyers has a spectacular aura about
[2017] Accuracy of scouting boiler goals...
After analyzing how scouts would potentially go about tracking a robot's fuel scoring ability, I came to the conclusion that there is virtually no way scouts will be able to make an accurate count of how many "fuel" balls are scored in the lower goal of the boiler. A cursory examination of the game leads me to believe that many robots will be scoring at this goal in bulk (think a "dump truck" robot design) that could be putting anything from ten to a hundred balls into the goal. There is no way that a scout will be able to accurately count each fuel ball that goes into the lower goal. This inexactness is a potentially scary problem that should be recognized by the greater scouting community.
How do you guys think we should adjust our scouting procedures to adjust for this potential inaccuracy?
FRC Team 980 Thunderbots
Programmer
Scouting Lead
Lead developer of ThunderScout
Unread 08-01-2017, 01:41
Joy4201 Joy4201 is offline
FRC #4201 (The Vitruvian Bots)
Team Role: CAD
Rookie Year: 2016
Joy4201 is an unknown quantity at this point
Re: [2017] Accuracy of scouting boiler goals...
One thing that was suggested on my team was to count cycles. How fast can a robot grab a good number of balls and dump? We also thought that we should make an estimate of the balls they have at each dump (maybe just low, medium, high).
Unread 08-01-2017, 01:52
AMendenhall AMendenhall is offline
FRC #3925
AMendenhall is an unknown quantity at this point
If you filled the entire volume of your robot with spheres, you'd only be able to fit 50 spheres in your robot. Proof:
Maximum volume of robot, M=34,560 inches cubed.
Volume of sphere, S=4/3*PI*5^3=523.6 inches cubed
Optimum packing order of spheres, P=0.74
Maximum amount of balls in robot: M*P/S=49. Q.E.D
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Good idea! In addition, scouts can estimate the accuracy too, and multiply that by the maximum capacity that team claims they can hold to get another reading of how many balls were scored per cycle.
I would imagine that high goal is easier to estimate than low goal though.
Unread 08-01-2017, 01:54
AKA: Thomas
Team Role: CAD
Not quite. The diameter of the sphere is 5", so the radius is 2.5". You're off by a factor of 8.
Edit: Also, the balls are slightly squishy. In addition, you can pile a hill of balls higher than your robot max height and hold them all.
Unread 08-01-2017, 14:49
legoguy1000 legoguy1000 is offline
FRC #2363 (Triple Helix)
legoguy1000 is an unknown quantity at this point
I have been thinking about this as well. My scouting application (https://www.frcscout.resnick-tech.com), which is open for every team to utilize, just has a button for a high or low goal. I was thinking about how to do bulk scoring and I think I will just have a drop down with increments and allow users to select the number to be submitted. Please feel free to take a look and let me know.
Unread 08-01-2017, 15:39
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Last year FMS tracked the high and low goals in teleop separately. I don't know if that will happen again this year or if it will happen in auto too, but TBA may be helpful in this regard (you would have to note if it seems if only one or if two or more robots are scoring in the low efficiency goal, but it may be better than nothing).
Name:	Boulder FMS Separation.png
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 08-01-2017, 15:58
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
For purposes of the kPa calculation, the FMS will have to keep track of Auto/TeleOp separately since Auto fuel counts for 3 times as much pressure. Also keep in mind that the processing of the fuel for Auto stops when Auto stops and anything left in the hopper is now TeleOp fuel. At the end of the match, the same holds true when at t=0, processing stops regardless of what was still in the hopper at the time. There is no "the ball was in the air so it counts" with this game.
Nate
Unread 08-01-2017, 16:04
They will definitely keep track of the number of balls (fuel). The question is whether scouts will be able to determine in the moment the amount. Also the FMS does not determine which robot did what, so there is no way to determine who contributed what number of balls based on the FMS / Blue Alliance data.
Unread 08-01-2017, 20:50
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
We'll probably make high ball scoring fall into 3 catagories:
A) Amazing!
B) Pretty good.
C) Meh.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 08-01-2017, 21:03
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
A) Amazing!
B) Pretty good.
C) Meh.
We're going to hopefully be better than 'Meh'!
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 08-01-2017, 21:17
FRC #3925
You're right. Redo:
Volume of sphere, S=4/3*PI*2.5^3=65.5 inches cubed
Maximum amount of balls in robot: M*P/S=391.
I revoke my skepticism about 100 balls being dumped into a goal.
Unread 08-01-2017, 21:44
Bronze Bronze is offline
FRC #0701 (RoboVikes)
Bronze is an unknown quantity at this point
Don't forget that that volume includes the bumpers... ~3.25 inches from each side of the robot that the frame perimeter must be held within. So maximally, robots themselves can actually only be 23718 cubic inches (and thats in the short orientation, its actually less in the tall orientation, at 21573 cubic inches).
Keep in mind that the random packing density is maximally 64% (optimal planned packing is higher, but thats not going to happen during a match). So we take the number of fuel that an empty space of the size that the robot could fit in to be only 231. Now consider that the robot needs electronics, a frame, wheels, and some mechanism to actually dump the balls, and I think you'd be lucky to see 100, maybe 150 ball dumps, if that's all the robot does.
Now for the discussion of scouting, we are considering the following for our electronic scouting app (that we plan to release before competitions start):
- go around before matches start and ask teams what the maximum number of fuel their robot can hold is, save that data in our app
- during match scouting, have a slider to estimate (to nearest 5 for low goal) the number of fuel scored by a robot, with a marker / upper limit just above the maximum capacity that the team reported their robot being able to score. Gives our scouters a way of visually going - "their robot looks about half full, so must be half of the number they reported", etc.
Unread 08-01-2017, 21:57
logank013's Avatar
logank013 logank013 is online now
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
I've talked about this with a few other members of my team since I'm the scout guy on our team. I'm sort of at a loss. We've had "super scouters" before. It'd be 1 per alliance along with 1 per robot. That means we'll need 8 scouts a match which might be a problem for us. But I've thought about designating super scouters where their whole job is to count how many balls each team on that alliance scores in the goals. It will be really hard to count low goals but high should be fairly easy. Good thing I have 6 weeks to figure this out...
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 08-01-2017, 22:11
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Calculate teams' component OPR for boiler points if you can. If that isn't doable, just count cycles and guesstimate "less than 30 balls" or "more than 30 balls," or something like that.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
[IMG] code is Off
