Go to Post Either this entry is the winner or Andy needs professional help. I can't quite decide which... - Rich Kressly [more]
Unread 07-01-2017, 22:55
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Knots in the rope?
On splices...
As I read it, an "end cap splice" of up to four inches in length would probably be OK (though that would be rather short for 1" line).
Slicing the rope along its length to another rope would require the splice to still be no larger than 1" in diameter (not too difficult if the line is 5/8" or smaller) would still be "braided" and allowed.
Splicing a loop into the end of the line (unless it were very short and could all fit in 4") would not be a knot and would not be allowed. (Say the last part three times fast.)
[Usual caveat that this is my opinion, not a Q&A answer.]
Unread 07-01-2017, 23:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
But they can be very stiff...
Better not make it too stiff for too long a distance:
Originally Posted by I04-D Bluebox
Flexible means that if the ROPE is held at any point, it should not extend more than 12” above the point where it is held. ROPES are meant to be pulled, not pushed.
Unread 07-01-2017, 23:54
LEGOlas798 LEGOlas798 is online now
FRC #1094 (Channel Cats)
Team Role: Driver
LEGOlas798 is an unknown quantity at this point
I can't help but think about this quote in rule I04, section D:
"consist entirely of flexible, non-metallic fibers twisted, tied, woven, or braided together except for the last 4 in. (~10 cm) of each end which may be whipped, fused, covered in heat shrink or tape, or dipped in a coating material to prevent fraying"
Does anyone know of a "coating material" that can be magnetized? Just an idea.
Unread 08-01-2017, 00:03
The Swag Muffin The Swag Muffin is offline
FRC #1094
The Swag Muffin is an unknown quantity at this point
Could you use a mettle crimp at the end of a rope to keep it from fraying.
"Consist entirely of flexible, non-metallic fibers twisted, tied, woven, or braided together except for the last 4 in. (~10 cm) of each end which may be whipped, fused, coveredin heat shrink or tape, or dipped in a coating material to prevent fraying."
Would mettle all so be excepted for the last 4 inches?
Unread 08-01-2017, 00:08
You can get magnetic paint/primer, but I suspect the GDC is going to shoot that one down on Q&A.
Do you see "crimped metal ferrule" in that list of end treatments? If you HAVE to have something metallic there, I think currently your options are magnetic paint or whipping it with steel wire/cable. I seriously wouldn't get my hopes up about that, though. I think that's likely to get shot down about a day after the Q&A opens.
Back on the knots subject, in case anyone hasn't done the math, it looks like the davit has about 22" of steel guide below where the attachment knot should go. So a knot in your rope should be about 7" below the steel channel of the davit. Not sure how far below the touchpad that puts you, but it's definitely close. I'm assuming y'all are thinking of regularly spaced knots and a notched pulley?
Unread 08-01-2017, 00:11
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
I want to add to this discussion that any of the modifications you can make to the last 4" of the rope must be in order to prevent fraying. This kind of thing will be inspected on a one by one basis, and if your rope has anything that the inspector deems not for the purpose of preventing fraying, they shouldn't allow it to pass inspection.
Unread 08-01-2017, 00:17
Registered Muser
The way I read the rules, I think that no metal of any kind will be allowed on any part of the rope. I think the non-metallic bit is meant to describe ALL parts of the rope. But don't take my word for it. This is probably a question for the Q&A. A team could decide to dip their ropes in molten aluminum or iron for some reason.
Unread 08-01-2017, 01:30
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
From the knots and loops school of thought, Ri3D 'Snow Problem is attempting a climber that will essentially act as a winch on a rope with a loop at the end, using rotating pegs and a cam cleat. We should have a video of our prototype on Monday (it's linked to our intake, and is basically just an interesting concept that isn't much of a risk for us if it doesn't work out).
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 08-01-2017, 10:26
I think that'll be a pretty common idea, yeah. Don't kill yourselves getting the cam cleat working though. If you can lift the whole way without it, your lift is good enough, since scoring is at the instant of T=0. If you've had the touchpad triggered for >1s before T=0, then you're good.
The cam cleat would save some battery since it'd hold you in place passively, and it'd give you a 1s margin, since triggering the pad at T=0 and maintaining for 1s also scores. But staying up there after T=0 definitely isn't a requirement this year.
Unread 08-01-2017, 10:46
AKA: Nick Aarestad
The entire plan regarding our climber is to not kill ourselves over getting it working-- we figure that whether we fail miserably or succeed wildly, or anywhere in between, the community learns something, which is why we're doing Ri3D in the first place.
tumblr | twitter
VEXU UMN (2015-??)
Unread 08-01-2017, 10:47
1247Robotics 1247Robotics is offline
FRC #1247
1247Robotics is an unknown quantity at this point
Originally Posted by markmcgary View Post
We've already found a vendor for retroreflective rope.
I didn't see any rule regarding how legal this was. It would be great if it was legal since we are hoping to leverage vision tracking this year.
Unread 09-01-2017, 15:44
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Regarding knots in the loop, are you allowed to make them in the provided rope, and not have it count as the custom rope for the alliance?
Any reference for an anwer?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 09-01-2017, 15:49
Registered Muser
I don't think there's a rule explicitly saying you can't, but your event staff will quickly come to hate you. Also, they could cite G02, specifically example J.
Unread 09-01-2017, 16:04
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
No rule to reference, but from a practical standpoint I expect the answer is no. Your whole rope, including knots must be less than 1" wide. If you put knots in the provided rope without getting it inspected*, there is no way to ensure that your rope follows that rule.
*on-field inspections are not allowed and you can't remove the provided ropes from the field
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-01-2017, 16:19
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
I don't think the alliance is limited to a single custom rope anyway. I think each team is limited to a single custom rope.
I also agree that the field's rope cannot be knotted, as it is not inspectable.
