Go to Post H.A.T.E.R.S. = Having Anger Towards Everyone Reaching Success - pandamonium [more]
View Poll Results: Fuel vs. Gears
Fuel 121 28.21%
Gears 308 71.79%
Voters: 429. You may not vote on this poll
Thread Tools Rating: Thread Rating: 5 votes, 4.60 average. Display Modes
  #31   Spotlight this post!
Unread 08-01-2017, 03:35
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Fuel Vs. Gears
Originally Posted by Aventek View Post
That is a very valid point, my main argument there is that you have to have a semi-fast shooter to make all 10 reliably within 15 seconds.
I fully expect Einstein alliances to put 100+ balls in the high goal in auto.
2001-2004: Team 100
2006-Present: Team 254
  #32   Spotlight this post!
Unread 08-01-2017, 04:00
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Fuel Vs. Gears
Originally Posted by Valkonn View Post
As such, a single robot probably can't get the RP from turning all 4 rotors.
Probably? Time to watch out for that robot at worlds then.
I agree, however (credit to pilleya for pointing this out):
Originally Posted by Manual 3.11.4
A BOILER processes FUEL in to steam at an average rate of five (5) FUEL per second per GOAL
So during autonomous period itself, only about 15*5=75 balls can be scored. How would the other balls be counted, if they aren't counted before autonomous ends?
It seems strange that FIRST would limit the dream of the perfect auto with a slow ball counter. To the Q&A we go!
  #33   Spotlight this post!
Unread 08-01-2017, 07:00
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
Re: Fuel Vs. Gears
They would be scored in tele-op, as mentioned in the field tour videos. FIRST pretty much states this is by design, so I don't think posting in the Q&A will change anything.
  #34   Spotlight this post!
Unread 08-01-2017, 07:44
Gdeaver Gdeaver is offline
FRC #1640
Re: Fuel Vs. Gears
Gears are all about cycle time. Look back to 2014 for an idea on cycle times. Now factor in the field is covered in fuel. If all the bins are dumped on the field, that's one mess of balls. Now what is the center line of a ball and what is the bumper height. What happens when your robot's bumper contacts the balls?
If your going to do gears, figure out how to drive in a sea of balls.
  #35   Spotlight this post!
Unread 08-01-2017, 08:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Fuel Vs. Gears
At this point, we're thinking gears as our primary function (and a rope climb of course).
If these both go smoothly, we have two likely paths for an additional manipulator:
Bee able to gather balls in passing and dump them into the low goal or at the same height as the HOPPER (we'll need to do tall configuration for this) to facilitate passing fuel to a high goal scorer who is set up to load at the HOPPER. We'll be sure to have an optional autonomous mode which begins with dumping our ten pre-load fuel (into an alliance partner) before scoring our gear.
Gather gears from the floor (and get them to our hanger).
  #36   Spotlight this post!
Unread 08-01-2017, 09:30
Jellypickles234's Avatar
Jellypickles234 Jellypickles234 is offline
"Not another constraint error..."
AKA: Dean Schmidt
FRC #0234 (234 Cyber Blue)
Team Role: CAD
Rookie Year: 2015
Jellypickles234 is on a distinguished road
Re: Fuel Vs. Gears
Originally Posted by MAXOFLIFE View Post
Actually, the autonomous gear is worth 60 points. This means that after you place the first gear in teleop, you're still at a 20 point deficit. Now you need to score 60 balls in the top goal to balance the score. While this is doable, it's still a significant inequality. The one rank point earned by reaching 40 kPA is nice, but not as good two rank points from simply winning the match.
I think he was saying that if you score the 10 fuel in the high efficiency boiler that is 10 points and 10 kPa, so when you score your pre-loaded gear for 40 points in teleop you are now 10 points behind the 60 point autonomous gear.
Cyber Blue: Sponsored by Rolls-Royce, Allison Transmission, and Morris Machine
  #37   Spotlight this post!
Unread 08-01-2017, 09:36
Aventek Aventek is offline
AKA: Kyler Novotny
FRC #3019 (Firebird Robotics)
Aventek is an unknown quantity at this point
Re: Fuel Vs. Gears
Originally Posted by who716 View Post
Although a lot of what you say makes sense that is one of the things I like the most about first as I see it alittle different.
I see the potential for a very fast shooter to lock up 40kpa in autonomous thus giving then a ranking point within the first 15 secounds. After auto it takes 3 times as long to reach the 40kpa limit tending it rather useless unless in a game that can both alliances can turn all four rotors...
Basically in my opinion hitting the top goal in auto an being able to hit 20+ in 15 secound which should not be hard. Makes get the extra ranking point a ton simpler and quicker
40 high goal is auto equals a ranking point
120 high goals in Telekom is a ranking point
Don't get me started on low goals
Except the thing you are forgetting is that you can only start with 10 balls in your robot, making 10kPa the cap.
  #38   Spotlight this post!
Unread 08-01-2017, 09:40
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Re: Fuel Vs. Gears
If you can trigger the hopper and collect and shoot those balls, it is possible to reach 40 kPa in auto
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
  #39   Spotlight this post!
Unread 08-01-2017, 09:57
AKA: Dean Schmidt
Team Role: CAD
Rookie Year: 2015
Re: Fuel Vs. Gears
Also that amount is under the hypothetical 75 fuel limit for counting during autonomous (15 sec * 5 fuel/sec)
  #40   Spotlight this post!
Unread 08-01-2017, 10:06
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Fuel Vs. Gears
realistically, this is helped timewise by shooting at both goals. our team is discussing this option. This brings the 40kPa fuel processing time from 10 seconds to around 6.
  #41   Spotlight this post!
Unread 08-01-2017, 10:34
hydroptix's Avatar
hydroptix hydroptix is offline
AKA: Samuel Frazee
FRC #1571 (CALibrate)
Rookie Year: 2016
hydroptix is an unknown quantity at this point
Re: Fuel Vs. Gears
Team 1571 is considering the possibility of shooting multiple fuel into the high goal at the same time. Each fuel is 5 in. wide, and the high goal is 21.5 inches wide with a decently accurate shooter (vision targeting will be handy here) it is possible to realistically score 2 or 3 fuel at the same time.
  #42   Spotlight this post!
Unread 08-01-2017, 10:42
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Fuel Vs. Gears
Is this true?
Is it 5 fuel/sec in the low goal and 5 fuel/sec in the high goal?
or is it just 5 fuel/sec?
___________________
- Tennyson, Ulysses
  #43   Spotlight this post!
Unread 08-01-2017, 10:50
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Re: Fuel Vs. Gears
Originally Posted by Daniel_LaFleur View Post
Is this true?
the high goal and low goal have separate processing and counting. Each averages ~5/sec
  #44   Spotlight this post!
Unread 08-01-2017, 10:54
mannybjh's Avatar
mannybjh mannybjh is offline
AKA: Ben Hogan
FRC #0020 (Team 20)
mannybjh is an unknown quantity at this point
Re: Fuel Vs. Gears
We debated the ability of just gears because they give a lot of points. But in order to get a Ranking Point, assuming you are the only robot placing gears, you need to make about 12 shuttle runs between the feeder and the airship. In previous years and games, some of the best teams were only able to make 7 or 8 runs across the field. We decided that is was seemingly impossible to get a Ranking Point by yourself. Just my thoughts.
  #45   Spotlight this post!
Unread 08-01-2017, 11:08
Azelf482 Azelf482 is offline
FRC #5994
Azelf482 is an unknown quantity at this point
Re: Fuel Vs. Gears
I think a lot of teams are going to prioritize gears over fuel. My concern with this is that gear-specific robots are a lot easier to defend against. There is no key to provide any protection, and your only choice to acquire gears is to traverse the field multiple times. I doubt we will see more than 2 rotors activated early on.
There is, however, a tech foul given to an opposing team if an opposing robot touches your robot with any part of it inside your retrieval zone, regardless of who initiates the contact (Rule G13). If your robot can reach the retrieval zone with a reasonable amount of speed, most robots won't be able to defend against you obtaining the gear. Even if they try not to touch you, in the retrieval zone, bumping them to still gives them a tech foul, because no one can touch you in the retrieval zone.
While it's true an opposing robot can just prevent you from reaching the retrieval zone in the first place, that's a lot harder to do, and depending on the robot, not worth the time and the points they could be scoring instead of preventing you from scoring.
