Go to Post the whole process is the most valuable part, not the award itself - Rich Kressly [more]
Unread 08-01-2017, 07:35
Dwight_2's Avatar
Dwight_2 Dwight_2 is offline
Student Co-Leader
AKA: Dwight Howard
FRC #5842 (Royal Robotics)
Rookie Year: 2016
Dwight_2 is an unknown quantity at this point
Re: Useless Gear Slot in Overflow Loading Station?
Originally Posted by seg9585 View Post
But the point is, one is not allowed to use the Overflow Loading station to enter gears onto the field, right? The rules specifically say that:
"An Overflow LOADING STATION is used to feed FUEL from the OVERFLOW BIN on to the FIELD. "
Does that inherently means you CANNOT use that loading station for any other purpose?
I may not be fully correct but I believe that the overflow station gear drop is for the gear the opposing alliance has not taken as preload for autonomous. so like if your alliance only takes one gear preload the other two go to the overflow on the other side of the field.
Systems Integration supervisor, CAD team, Drive team, Programming team (2016), Student team Co-Leader, Documentation Chair (2017)
"It Doesn't Get Easier. You Just Get Better."
