Go to Post P.S. Who doesn't have CD as there homepage! (I mean, come on people. It's not like there's anything else to do on the net... :)) - Ryan M. [more]
Unread 07-01-2017, 16:40
WSiggs WSiggs is offline
Pb Programmer
FRC #4908 (Dragons)
WSiggs is on a distinguished road
Useless Gear Slot in Overflow Loading Station?
In the Overflow Loading Station in each teams Alliance Station, there is a gear slot like that of the Return Loading Stations. Next to each Return Loading Station there are stacks of gears to be put into play by the opposing alliance, and there does not appear to be a stack for the OLS. This begs the question as to why there is a gear slot on the OLS. The game manual says "An Overflow LOADING STATION is used to feed FUEL from the OVERFLOW BIN on to the FIELD." and there is no mention of gears being inputted. Am I missing something or is this a useless slot?
Unread 07-01-2017, 16:44
Re: Useless Gear Slot in Overflow Loading Station?
Game pieces that somehow migrate out of the Loading Lane into the Alliance Station belong to the Alliance that owns that station. Section 4.6.
Also, sometimes if something is just a little off, it makes sense to just build it the same. FIRST is building 6 loading stations per field, may as well just build them all the same as it's one less part number to track.
Unread 08-01-2017, 00:17
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
But the point is, one is not allowed to use the Overflow Loading station to enter gears onto the field, right? The rules specifically say that:
"An Overflow LOADING STATION is used to feed FUEL from the OVERFLOW BIN on to the FIELD. "
Does that inherently means you CANNOT use that loading station for any other purpose?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 08-01-2017, 07:35
Dwight_2's Avatar
Dwight_2 Dwight_2 is offline
Student Co-Leader
AKA: Dwight Howard
FRC #5842 (Royal Robotics)
Rookie Year: 2016
Dwight_2 is an unknown quantity at this point
I may not be fully correct but I believe that the overflow station gear drop is for the gear the opposing alliance has not taken as preload for autonomous. so like if your alliance only takes one gear preload the other two go to the overflow on the other side of the field.
Systems Integration supervisor, CAD team, Drive team, Programming team (2016), Student team Co-Leader, Documentation Chair (2017)
"It Doesn't Get Easier. You Just Get Better."
Unread 08-01-2017, 08:07
NicusTM's Avatar
NicusTM NicusTM is offline
AKA: Nic
FRC #3216 (Missoula Robotics Team)
Team Role: Student
NicusTM is an unknown quantity at this point
The gears that aren't preloaded are added to the 18 gears in the loading lanes, so they don't go to the overflow loading stations. (pg 40)
Unread 08-01-2017, 08:15
linzerin linzerin is offline
FRC #1756
linzerin is an unknown quantity at this point
That kind you for posting this question, we had the same confusion/conversation. Ultimately, we agreed that no gears would be loaded from the overflow station and it was designed that way simply to be consistent with the other stations.
Unread 08-01-2017, 08:18
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I don't think you are correct.
Originally Posted by 4.2 Match Setup
GEARS
D. One (1) available to each team to preload in their ROBOT (any not preloaded are staged with GEARS in E)
E. Eighteen (18) in each LOADING LANE (staged on the carpet between the LOADING STATION and the STARTING LINE)
F. One (1) in each AIRSHIP
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 08-01-2017, 08:19
FRC #1756
Thank you for posting this question, we had the same confusion/conversation. We couldn't find anywhere in the manual that discussed gears being loaded from that station. Ultimately, we agreed that gears would loaded from the other two feeder station a and it was designed that way simply to be consistent with the other stations.
Unread 08-01-2017, 09:28
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
You start with 30 fuel and 3 gears behind your alliance station wall that can be introduced during Tele. These 3 gears are separate from the 3 gears that you are able to load into your alliance's robots in Auton.
Unread 08-01-2017, 09:31
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
That is incorrect
GEARS
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
