Go to Post In conclusion we will have a spaghetti game - Darkseer54 [more]
Old 03-01-2017, 08:29
Hello_There Hello_There is offline
FRC #5928
Hello_There is an unknown quantity at this point
OM5P-AN router is not giving a gateway
Hello,
After being in a local FRC competiton (radio configured because of FRC event)
I tried to configure it for home use again but Im not seeing default gateway on radio.
How can i resolve it and configure it again?
Old 03-01-2017, 08:35
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: OM5P-AN router is not giving a gateway
This should be what you're looking for
http://wpilib.screenstepslive.com/s/4485/m/13503/l/144986-programming-your-radio-for-home-use
#StaySavage
Old 03-01-2017, 08:42
Are you saying it's assigning an IP, but not a gateway? A gateway is not necessary for FRC use.
A gateway is only used when trying to reach an IP outside the local network, which in the FRC use case, there is no way to reach.
Unread 08-01-2017, 07:45
FRC #5928
I tried several times with the frc radio configuration and I still cant configure it. it says it cant connect to ip bridge.
Unread 08-01-2017, 10:02
Tell us what steps you took and we can probably help.
Did you?
- Disable all other network connections, e.g., wireless
- Connect via Ethernet cable
- Skip any of the screenstep instructions because you didn't think they were important
- Are you setting it up as an AP? Your laptop can only connect to an AP, NOT a bridge.
- Are you using 2.4GHz or is your laptop capable of 5GHz (or whatever the Israeli restrictions are)?
Unread 08-01-2017, 16:36
FRC #5928
Did you?
Yes, tried all. im reading the router from my PC but there is no gateway and the router still showes red lamp on wifi.
Unread 08-01-2017, 16:54
Red status light for WiFi usually means it is in Bridge mode, but has not connected to any other wireless point yet. It only goes green after someone connects to it wirelessly.
In AP mode it usually goes from red to yellow.
No gateway settings are required for our use.
On your PC wireless choose it does not list an AP labeled 5928?
You have to choose to connect to it.
