Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
  #31   Spotlight this post!
Unread 08-01-2017, 11:07
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Re: What's the best rope?
Originally Posted by engunneer View Post
yes, the manual shows a strap as a legal possible rope, and even shows examples of ropes with knots and loops.
I honestly think they suggested it to reduce the Q&A on the topic about whether ropes need to be round in cross section (they do not).
grabbing and climbing any dangling flexible object seems tricky. I like the way they designed this.
I'm surprised. Now with this discovery a team can make a drum winch. Original presentation made us feel we are climbing more like a human would. As you climb you pass the rope through not coil it up.
Yes grabbing the line could still be tricky
  #32   Spotlight this post!
Unread 08-01-2017, 11:08
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
you'll have a hard time getting the rope off the davit if the robot is actively against the touchpad and the section of rope between the robot and the davit is under tension.
Design your winch so it unreels (slowly) when the match is over.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #33   Spotlight this post!
Unread 08-01-2017, 11:12
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Levi Madden is on a distinguished road
Originally Posted by carpedav000 View Post
So according to the rules, velcro may be considered a rope as it's flexible and non metallic. Is this correct?
Just remember that G15-C states you can not attach to the field using hook and loop (AKA velcro). When you add your own rope, it becomes part of the field, therefor, you could use velcro as a rope, but you can not attach to it.
  #34   Spotlight this post!
Unread 08-01-2017, 11:31
icomella icomella is offline
FRC #0639
icomella is an unknown quantity at this point
Yes, but the loops can only be 10" in diameter.
  #35   Spotlight this post!
Unread 08-01-2017, 11:53
Maxwellfire's Avatar
Maxwellfire Maxwellfire is offline
AKA: Max Tepermeister
FRC #2877 (LigerBots)
Maxwellfire is an unknown quantity at this point
I was thinking about something like this for our team. There's no minimum diameter listed, and I think that coiling a smaller rope would be easier. (Wrapping the field rope around a pulley seemed impossible). The only question is whether you can tie a large enough knot in the end to satisfy the > 1" requirement at the top.
  #36   Spotlight this post!
Unread 08-01-2017, 12:35
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
getting a 1" know is just a matter of a bigger more complicated knot (I suggest a monkey fist in the extreme case).
I'm not sure i would trust a robot to just a 325 lb tensile strength. a robot will be a pretty dynamic load, and the rating goes down quickly if there is any damage. Test test test!
  #37   Spotlight this post!
Unread 08-01-2017, 12:53
Riri700 Riri700 is offline
AKA: Riley
FRC #5938 (Razor steel tobotics)
Rookie Year: 2015
Riri700 is an unknown quantity at this point
Originally Posted by Moonsault View Post
Does this mean it can be looped also?
The rule book states that you can use a loop. But it cant be rigid? it needs to be loose. So if pulled on it tightens. And it cannot be any larger than 10" in diameter.
This can be found on page 100 for specifics.
  #38   Spotlight this post!
Unread 08-01-2017, 13:14
COL Woodchuck COL Woodchuck is offline
FRC #0706
COL Woodchuck will become famous soon enoughCOL Woodchuck will become famous soon enough
I believe the rules in G15 make an exception on the rope so a velcro rope of "loop" and a winch drum with "hooks" would be allowed.
From G15:
Items A-G exclude ROPES installed on an ALLIANCE’S AIRSHIP.
A. Grabbing
B. Grasping
C. Attaching to (including the use of hook-and-loop tape against the FIELD carpet)
D. Grappling
E. Hanging
F. Deforming
G. Becoming entangled
  #39   Spotlight this post!
Unread 08-01-2017, 13:59
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
I believe this only applies if you use the velcro to strategically hold the rope in place by attatching it to the carpet.
It isn't shiny enough.
  #40   Spotlight this post!
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The field drawing doesn't show anything nice about the 90 degree turn the rope makes in the davit. It's shown as a square tube butted against sheet steel bent into a channel, with some weld. I wouldn't expect it to be sharp, but it's not going to be nicely rounded either. And a smaller rope is much more likely to swing and scrape across the edge than a larger one.
  #41   Spotlight this post!
Unread 08-01-2017, 19:01
saintblaze4639's Avatar
saintblaze4639 saintblaze4639 is offline
FRC #4639 (The RoboSpartans)
Team Role: Driver
Rookie Year: 2016
saintblaze4639 is an unknown quantity at this point
how about velcro, as according to the Ri3d 1.0 video?
  #42   Spotlight this post!
Unread 08-01-2017, 19:04
Steph342's Avatar
Steph342 Steph342 is offline
FRC #5508 (Career Magnet Academy)
Steph342 is an unknown quantity at this point
Is there anything preventing you from using a nylon strap and a drum with barb wire to suck in the rope and winch yourself up?
Team #342 Alumni
Team 5508 Mentor
  #43   Spotlight this post!
Unread 08-01-2017, 19:23
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Amsteel blue is another really good option that I've worked with in the past. Very strong, and super easy to work with, and manipulate.
Check out specs: http://www.samsonrope.com/Pages/Prod...?ProductID=872
And a tutorial on fixing an eye in your rope: https://www.youtube.com/watch?v=Q22wgYZL9f0
  #44   Spotlight this post!
Unread 08-01-2017, 22:49
Offhand, I'd say the inspectors that will take one look at your drum of barb wire, facepalm, and start patiently explaining the safety rules.
  #45   Spotlight this post!
Unread 08-01-2017, 23:46
Rookie Year: 2015
There is going to be a long Q and A on this one stand by. So many different ropes and straps. I'm supersized they only gave one example and did not spec minim diameters of weights.
