Go to Post This is far more then any little school extracurricular, this is a FIRST Robotics Team. - onecoolc [more]
Unread 08-01-2017, 12:40
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Re: Does anyone know if the gear lift protrusion is allowed to go into the robot and
Keep in mind the gear lift will not "grab" the robot. The robot cannot grab the gear lift by rule since it is part of the field. I see nothing in the rules that would prevent the robot from having the gear lift protrusion from extending into robot frame perimeter even with incidental contact with the robot. Which I think is the answer to your question?
