#16
Re: WPILib Suite 2017
What is the difference between the 2016 C++ toolchain and the one for this year (2017)? I can't seem to find a changelog, and they're supposedly the same GCC version.
#17
The installer itself had a few bugs fixed, and it has a new sysroot to match the 2017 image. The compiler version itself is the same.
#18
Does anybody know where the API/Documentation is for the CTRE CANTalon library? It is not on the first wpilib documentation and I can't find it anywhere on the CTRE site.
My team uses Java. Last year the CANTalon library used to be built in to the WPILib but now it is part of the 3rd party libraries from CTRE. I have gotten that setup on my development machine but I can't find any documentation anywhere on classes in the library (javadoc). Last edited by apache8080 : 08-01-2017 at 02:40. |
#19
EDIT: Never mind, found it Last edited by demosthenes2k8 : 08-01-2017 at 15:22. |
#21
So where does one find out what the appropriate import statement is? I have not been able to locate any doc for the CTRE library.
#23
The import statements are: import com.ctre.CANTalon; // The main CAN talon device import com.ctre.CANTalon.FeedbackDevice; // The modifiers for the CAN talon device import com.ctre.CANTalon.StatusFrameRate; import com.ctre.CANTalon.TalonControlMode; After that use them as per last year. For teams that did not keep last year's javadoc (or don't have a 2016 install) there isn't any source on the CTRE web site yet. I'm hoping that they will remedy this soon. |
#24
Migrating from 2016 to 2017 is explained in section 3.1.1 of the Talon SRX Software Reference Manual.
#25
is it possible to get a javadoc to go with the new library, or is the SRM the only reference available? |
#26
We'll put up a javadoc soon, stay tuned. But in the mean time, I would take a look at the ref manual and our github examples.
#27
Sorry I'm late to the party all. Are we saying that there is no javadoc up yet for the CANTalon library?
#28
Has anyone actually written a sample program in either CPP or JAVA using the CTRE 2017 download for CANTALON (as opposed to TALON)?
In particular., declaring a m_cantalon object, instantiating the m_cantalon object, and creating both an open-loop and and a closed-loop mode for the m_cantalon object. For me TALON works(no closed-loop obviously), but CANTALON doesn't. Both CPP and JAVA replies to this post will be appreciated. |
#29
Of course that was done, by us and by beta teams. And for the most part all you need to do is add an import/include for pre2016 cpp/java projects to work. Is there a specific problem you are seeing? Did you follow the steps in section 3.1.1 of the Talon srx software reference manual? |
#30
I'm probably confused by the maven repo structure, but I don't see anything from 2017 under http://first.wpi.edu/FRC/roborio/maven/release/. Am I looking in the wrong spot?
