Go to Post Javelins, armadillos, and rhubarb pie haven't been used as game pieces yet, either. Just sayin'. - Travis Hoffman [more]
Unread 08-01-2017, 13:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: What's the best rope?
Originally Posted by Riri700 View Post
The rule book states that you can use a loop. But it cant be rigid? it needs to be loose. So if pulled on it tightens. And it cannot be any larger than 10" in diameter.
This can be found on page 100 for specifics.
The field drawing doesn't show anything nice about the 90 degree turn the rope makes in the davit. It's shown as a square tube butted against sheet steel bent into a channel, with some weld. I wouldn't expect it to be sharp, but it's not going to be nicely rounded either. And a smaller rope is much more likely to swing and scrape across the edge than a larger one.
