Go to Post Frankly, I love CD and everything it stands for. I've made more friends from this forum alone than I ever expected to meet in FIRST. I'd give just about anything to keep this system up, upgraded and going on long into the future. It's not even enough to show my thanks and gratitude. - BandChick [more]
Unread 08-01-2017, 14:13
Blasteroid Blasteroid is offline
Blasteroid is an unknown quantity at this point
Specialized Robot for partnering? Fuel or Gears
Hi, what are your thoughts about creating a specialized robot just for posting gears? ... just for fuel? If a robot team specialized in fuel, would it be more likely to be picked as a partner by a robot team that specialized in gears?
If a team specialized on gears it stands to reason that it would be more time efficient with the task because the design team will have fewer competing priorities. Although there are a limited number of gears, time appears to be a more limited resource.
It also appears that gears and fuel are independent game elements. As discussed in this thread.
Would two specialized gear robots be better or worse? Better at scoring the gears, but might get in the way of each other.
What are your thoughts?
Unread 08-01-2017, 14:15
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Specialized Robot for partnering? Fuel or Gears
Elite teams will be able to get the pressure RP by themselves, but getting the gear RP alone is insanely difficult. Every robot should be able to score 2 gears themselves in a match.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 08-01-2017, 14:16
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
I feel like the robots that specialize in gears and do it well (8+ per match) will definitely be priority picks in eliminations, as it seems more likely that robots that specialize/can also do fuel will most likely rank higher.
It isn't shiny enough.
Unread 08-01-2017, 14:18
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
This would be my personal suggestion. Maybe with one of these on the front.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 08-01-2017, 14:25
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Most definitely.
There are some high scoring and high reward options in STEAMWORKS that only require the completion of one task (as you said, they aren't linked). Teams may see this and decide to focus on a single aspect of the game.
However, I feel like there are simple enough options for robots who specialize in one thing to still assist in another department. For example, it's likely quite possible to make your gear manipulator very compact. You could use the remaining space for a large container to hold balls that you retrieve with your balls specialist on your alliance from a hopper. This would be helpful to alliance robots that don't use a floor intake and want to ensure that their opposition (that has a floor intake) has less balls available.
Of course, this is only one theoretical situation out of many. Some cross over is beneficial, especially if you can fit a mechanism for said cross over on your robot.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
