Go to Post The battery will be mounted at the top, correct? There can be no other way. - Travis Hoffman [more]
Unread 08-01-2017, 15:03
Southpaw's Avatar
Southpaw Southpaw is offline
AKA: Spencer Robinson
FRC #3184 (Blaze Robotics)
Southpaw is on a distinguished road
2017 Drive Train
There's obviously a lot of debate surrounding which drive trains can serve what purposes. This thread is created to centralize this discussion to provide easier access to all teams.
One of the more uncommon drive systems which still proves useful is the h-drive. This system has omnis on all corners, with a central omni to provide lateral movement. Our team has thrown around the idea of using h-drive as a less complicated mechanum system. The movement is near-identical to mechanum and debatably easier to build. This of course being in contrast to using tank drive (reliable and simple). Can we get some insight?
Unread 08-01-2017, 15:11
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: 2017 Drive Train
I'm not sure how a h-drive is simpler to build. With mecanums, you simply just mount wheels on each corner. The stock AM14U3 chassis even has support for it with Toughbox Micros. Meanwhile, with a h-drive you have to add a cross member and have a whole different drive wheel and gearbox in the middle. With H-drive you can have three gearboxes (you can tie the two side wheels together), but you need at least 5 motors. Mecanum has four gearboxes but four motors needed. Both offer challenges, but a mecanum drive is a lot simpler to mount to some versa chassis quickly (or c-channel as my team uses) and get started.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 08-01-2017, 16:48
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
This year might be more of a swerve drive game than previous years. More control of the drivetrain can help place gears, and there's a wide open field for swerve to dance around defense in. It combines the advantages of omni or mecanums (and more) without giving up resistance towards defensive robots.
Too bad I'm not confident in my team's ability to do swerve properly.
Unread 08-01-2017, 20:25
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Mechanically, H-drive is harder to make because you need the center wheel, but programming-wise, assuming you're writing your code from the ground up, H-drive is a breeze compared to Mecanum.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 08-01-2017, 22:22
C_4187 C_4187 is offline
FRC #4187
C_4187 is an unknown quantity at this point
Mecanum vs. Tank?
Mecanum has an obvious mobility advantage, but how much does it really give up in traction/strength? Is it completely outclassed in strength to a tank drive system?
Unread 08-01-2017, 22:24
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
If there was ever a game to not overthink your drivetrain and just build a really simple tank drive, this would probably be it.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 08-01-2017, 22:27
Munchskull's Avatar
Munchskull Munchskull is online now
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Agreed. Make it simple strong and compact
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud of
Originally Posted by C_4187 View Post
Mecanum vs. Tank?
In a pushing match, yes.
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 08-01-2017, 22:46
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
Everyone should read this before building anything but a tank drive:
http://www.simbotics.org/resources/m...rain-selection
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
Unread 08-01-2017, 23:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Point to consider:
6-WD tank (preferably with a COTS shifter) is the fastest, easiest drivetrain to implement and program. Is a mecanum, H-drive, or swerve so much easier to line up that it outweighs the extra practice time you should have with the tank drive? Or the extra practice time with your practice bot because the tank drive is so much cheaper?
Also, a defensive tank bot is going to shove a mecanum or h-drive all over the place. Good luck scoring a gear while that's happening.
Unread 08-01-2017, 23:24
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Originally Posted by Kevin Sevcik View Post
Point to consider:
Aw man, if only I were still with Texplosion, that last part is a pure gem.
Yeah, don't overthink the drivetrain. You shouldn't need a vertical adjustment for anything. And, if you are off horizontally, build it into a mechanism rather than moving the whole robot. If you are placing a gear, have a way to rotate it or move it side-to-side. If you are a shooter, have a way to rotate your shooter to keep it on target. Put your code into things like that, not into complex drive.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 08-01-2017, 23:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
In 3946's experience, H-drive is harder than mecanum.
In 2013 Aerial Assault we decided to do mecanum (foolishly expecting a less defensive game), and it worked as well as expected, pretty much the first time around (OK, after fixing some wheel order issues), but we had it running two weeks after we made the decision on our prototype "Woody" (which meant ordering wheels and extra gearboxes before we could finish the build) and running like a champ on the competition robot "Buzz" before bag day. We used the WPI mecanumDrive class straight up, without encoders.
In 2015 Recycle Rush, we decided to do H-drive, and never got it working correctly all the way through CMP. It was only after the 2016 season that we got it working. If you do do H-drive, do not depend on a fixed-height strafe wheel - there is no height which provides the correct amount of load. The central wheel(s) must somehow have a controlled force against the carpet, whether passively through springs or actively through pneumatics or torque actuation, or perhaps some other ways you can come up with.
Another caveat which may or may not apply to you: H-drive requires a wheel near the CoG of your chassis (or one forward and one behind). This will interfere with the "chassis opening and combine" style gatherer that is likely to be commonly used by fuelbots this year.
Unread 08-01-2017, 23:45
RoboAlum RoboAlum is offline
Mickey D's
FRC #4841 (Optimal Robotics)
RoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the rough
we are actually gonna use 610s DT from Ultimate Ascent but wooden mobility for us was not a big thing for us this year we want to just be a role player and focus on the gears but still win a pushing a match
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 08-01-2017, 23:59
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Originally Posted by RoboAlum View Post
we are actually gonna use 610s DT from Ultimate Ascent...
For those of us who aren't familiar with it, mind providing some details about what this is?
Unread 09-01-2017, 00:10
Division by Pirates
Link to picture: https://goo.gl/images/pvbwyc
6 CIM, 6 Wheel Drive, single speed. I believe it was designed around acceleration, not a very high full speed.
