Go to Post This thread has officially jumped the shark! the old guy shark :) - IndySam [more]
Unread 08-01-2017, 08:21
waffle_dynasty waffle_dynasty is offline
FRC #5010
waffle_dynasty is an unknown quantity at this point
Wheels. Wheels. Wheels.
Last year pneumatic wheels were the most popular wheels used on a drive train. My question is: What wheels are you using for Steamworks and why?
Unread 08-01-2017, 08:28
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Wheels. Wheels. Wheels.
My team is nowhere near this point of brainstorming yet, but I expect most teams will use 4 inch rubber treaded or treaded wheels due to the less reduction needed and therefore less weight. I don't really see any reason you would need bigger wheels. Just speculation though.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 08-01-2017, 08:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Almost certainly solid rubber wheels. 4 inch (2014 KoP) most likely because we already own a bunch, but we'll make that decision after we figure out our design speeds.
Unread 08-01-2017, 09:30
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
We're thinking that we'll need mecanum wheels, for a few reasons.
1. Lining up with the gear peg will be much easier if we can slide laterally after we target it with our vision system. If we went with a normal drive base, we'd have to curve ourway into alignment, which seems to be too much trouble.
2. It would be very nice to glide sideways right into the hoppers, so as to get one set of 50 fuel to fall into our basket. I'm not sure this would be possible on a robot with normal wheels unless the wide side of your robot was the front.
Unread 08-01-2017, 13:16
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Be sure to heavily consider the fact you will be driving to the feed chutes on the opponent side of the field to get gears and fuel at some point. Mecanums usually mean you're easily pushed around by a standard drive robot.
This is coming form personal experience.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 08-01-2017, 13:22
NathanStro's Avatar
NathanStro NathanStro is offline
Webmaster for 5980
AKA: Nathan Strodtbeck
FRC #5980 (East Grand Rapids Robotics)
Team Role: Webmaster
Rookie Year: 2016
NathanStro is an unknown quantity at this point
Our team noticed that the gear mounting peg had vision system capabilities. It seems like mecanum wheels would be very good to realign to place the gear on the airship.
Its not about the robot
Unread 08-01-2017, 13:38
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
#ColsonLife
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 08-01-2017, 14:44
Sam Skoglund's Avatar
Sam Skoglund Sam Skoglund is offline
FRC #2232 (Deus Ex Machina)
Sam Skoglund is a jewel in the roughSam Skoglund is a jewel in the roughSam Skoglund is a jewel in the roughSam Skoglund is a jewel in the rough
We are most likely going with 3.5" diameter Colson wheels. Small ground clearance should be fine and it works well for our gearing and speed.
Unread 08-01-2017, 15:43
ttnn58 ttnn58 is offline
FRC #4586
ttnn58 is an unknown quantity at this point
where did you read that?
Unread 08-01-2017, 15:58
MonroeM MonroeM is offline
FRC #3570
MonroeM is an unknown quantity at this point
This year is great because of the field surface. No obstacles to beat your robot up with. This year we can finally use our new set of omni wheels. They will be great for maneuvering for shooting and placing gears.
The game this year will be fast and furious. Skill will over take brut force this time.
Unread 08-01-2017, 16:00
tpvagnini tpvagnini is offline
FRC #3236 (Tri-Force)
tpvagnini is an unknown quantity at this point
Section 3.13 Vision targets. 1st part discusses boiler high goal and then 2nd part discusses gear target strips.
Unread 08-01-2017, 17:01
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Most likely the 3in x.875in Colson wheels.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 08-01-2017, 17:03
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Going with 4" by 1.5" Colsons.
Don't want to have to worry about the drive wheels.
Unread 08-01-2017, 22:15
bmccarthy bmccarthy is offline
FRC #4456
Rookie Year: 2016
bmccarthy is an unknown quantity at this point
I think defense will be pretty big this year. It seems that only the boiler is protected from interference. I think hitting teams trying to place gears will be a fruitful strategy.
Unread 09-01-2017, 00:19
botster botster is offline
botster is an unknown quantity at this point
What would be the advantages of Colsons over the Andymark performance wheels with the blue roughtop tread (http://www.andymark.com/product-p/am-3309.htm)?
