Go to Post There can never be enough help, unless there's too much help. - Joshua May [more]
Unread 08-01-2017, 14:25
bobby.rein bobby.rein is offline
FRC #4404
bobby.rein is an unknown quantity at this point
Defensive climbing bot??
Would a defensive bot that climbs be a strong idea for a rookie team or low resource team? Could also add a passive gear mechanism.
Unread 08-01-2017, 14:31
jayred1127's Avatar
jayred1127 jayred1127 is offline
Javion Smith-Sanders
FRC #4571 (Rambots)
jayred1127 has a spectacular aura aboutjayred1127 has a spectacular aura aboutjayred1127 has a spectacular aura about
Re: Defensive climbing bot??
Climbing would be a big undertaking. I think as a rookie team a good focus would be scoring fuel and a lot of it.
Unread 08-01-2017, 14:35
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
I feel like climbing might be a bit tricky for a rookie. With that being said - prototype it. Perhaps we're all overestimating the challenge of hanging on a rope.
An easier option that still presents you as a competitive force on the alliance could be a low goal dumper (large capacity) with a passive gear scorer.
This design also allows you to play defense, of course, should you be on a very strong alliance.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
Unread 08-01-2017, 14:36
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
I think this would a be a very strong robot and would be picked at almost every regional/district event as at least a third robot. Being able to place a couple gears would just be icing on the cake.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 08-01-2017, 14:50
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
If you have a really good idea for the climber, by all means go for it. I would think that scoring lots and lots of fuel and gears would be an easier robot, but maybe not. Something to consider with climbing is that there is no rule that I can find that says a defending robot cannot try to keep you from getting to your rope. This means that if a robot can't climb they may devote their last seconds of the match trying to keep you away from your airship. A similar strategy was able to shut down some climbers back in 2013 with a simple "pizza box" robot defending the other pyramid.
I didn't break it... this time.
Unread 08-01-2017, 15:20
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
The only rule related is
G20.
Let ‘em climb: don’t touch their ROPES. During the final thirty (30) seconds of a MATCH, ROBOTS may not contact an opposing ALLIANCE’S ROPE.
Unread 08-01-2017, 15:43
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Originally Posted by AndyBare View Post
The only rule related is G20.
Also...
Originally Posted by G07
G07. Opponent touching their ROPE: don’t touch them. ROBOTS may not contact an opposing ROBOT, regardless of who initiates the contact, if the opposing ROBOT is in contact with one of its own ALLIANCE'S ROPES.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 08-01-2017, 15:52
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
cj3958 will become famous soon enough
My advice to you is make sure your gear ratio is high enough and you put a ton of motors on the climbing mechanism. Those are the two biggest ways rookie teams screw up climbing like this. Since you would not be close on weight, I would take a drive train gearbox from vex pro and put 3 cims/775's on it. Then get the right ratio.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 08-01-2017, 16:08
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Something you might want to keep in mind is if you have a defensive bot you want it to be as heavy as possible and it to use all 6 cim motors in the drive train. Giving your robot those capabilities would make climbing much more difficult.
2016, 2017 Colorado FLL Champions
2014 FLL North American Invitational, 1st place Strategy and Innovation Award
2014, 2013 Kentucky FLL Champions
2nd place Strategy and Innovation Award
FLL Team Automaticus Rex, Team Captain('11-'14) youth mentor ('15-'17) FRC Team 4418 Member ('14-') Design Lead ('15-17')
Unread 08-01-2017, 16:55
FRC #4404
Okay thanks for all the input. My team is choosing between two designs i came up with.
Design 1: A shooter bot that has floor pick up of fuel and a carrying capacity of 50+. Strategically we would shoot balls in boiler high goal for the entire time and never stop.
Design 2: A climbing robot with a passive gear mechanism. Auto Strategy: Put gear on the lift. Teleop Strategy: Decide between gears and defense based on opponent strengths. End Game we would climb.
Which design do you think is more likely to get us to elimination matches?
Unread 08-01-2017, 17:36
Originally Posted by Ari423 View Post
Also...
Thanks, forgot that one, but super important.
Unread 08-01-2017, 17:41
Also, Bobby, I think that one thing I'll mention is not only remember to think what your opponents are capable, but also the members of your alliance. Make sure you know how many gears are worth scoring. If you know that your alliance can score six gears in a match, go for it. If you are the only gear scorer, and can score only five, however, there is no point in scoring more than two. This game is very much about prioritizing scoring, and the balance between raw score, and kPa score.
Essentially think of each rotor as a check box. If you know you'll be able to cross it off, go for it. If not, use your time elsewhere.
Unread 08-01-2017, 17:55
FRC #4404
That is a good point thank you.
Unread 08-01-2017, 18:38
Ari423's Avatar
FRC #5987 (Galaxia)
A 50+ hopper is not something to just assume you can do. Each fuel is a 2.5" radius sphere, with a volume of 65.4in^3. Spheres packed at random have a ~60% packing efficiency, so each fuel has an effective volume of 110in^3. A 50 fuel hopper would need a volume of ~5250in^3, or a cube with sides of ~17.5 in. That's not something to assume you can fit in your robot. Let me be clear: I am definitely not saying it is not possible or even that your team can't achieve this. Just that you should make sure your robot can fit such a big hopper, a floor intake, and an output method all inside the volume limits.
2013: Programmer
Unread 08-01-2017, 18:44
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
If a team can figure how to make a 80 pound robot climb, they can probably figure out how to make a 120 pound robot climb.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
