Go to Post Safety glasses may be a nice forehead protector, but thats not what they are made for. - Quatitos [more]
  #31   Spotlight this post!
Unread 08-01-2017, 17:24
Thayer McCollum's Avatar
Thayer McCollum Thayer McCollum is offline
[Insert Name Here]
FRC #0159 (Alpine Robotics)
Rookie Year: 2015
Thayer McCollum will become famous soon enoughThayer McCollum will become famous soon enough
Re: Auto Rotor Point Total?
Originally Posted by Cothron Theiss View Post
It's definitely possible, but it requires all three robots to place a gear. I imagine that situation will be about as common as 70 point autos were for Stronghold.
I expect three gear/two rotor autos will be even less common because not only do all three robots have to deliver a gear but two humans have to retrieve three gears, then place one of them on the center spot, fit the other two into their spots and spin the crank three times. I just don't think that the pilots will be able to move fast enough for that to happen. I expect we'll see it once or twice but no more than that.
  #32   Spotlight this post!
Unread 08-01-2017, 17:28
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Originally Posted by ollien View Post
Interestingly, unless I'm missing something, the manual doesn't reflect this "three full rotations" bit. Only the field tour.
According to the field tour, the FMS doesn't recognize that the GEAR set is being rotated until after three rotations, so that indicates to me that the scoring will coincide with the rotor actually turning, or in case of a field issue, the corresponding light activating.
I do wish that the manual didn't say the GEAR sets "engage the corresponding rotor." That implies to me that the GEAR sets are physically meshed with the rotor, when the field tour explains that the GEARs drive an encoder, which tells the FMS to turn on the rotor.
  #33   Spotlight this post!
Unread 08-01-2017, 18:06
Zeke E's Avatar
Zeke E Zeke E is offline
Shop Slave/Mechanical Master
FRC #4329 (Lutheran Roboteers)
Rookie Year: 2016
Zeke E is an unknown quantity at this point
Looks like we've got ourselves a steamacrit. It is odd that we don't have any written proof of how many rotations it takes, if there is a set number. Field tour makes sense, but I just can't bring myself to trust something not in the manual.
  #34   Spotlight this post!
Unread 08-01-2017, 20:43
Josh Tatum Josh Tatum is offline
FRC #0303 (T.E.S.T team)
Team Role: Electrical
Josh Tatum is an unknown quantity at this point
Re: Scoring of rotors
If they do not change the rules, a team could take the reserve gear and put it into the first Rotor. This would get them the 100 points but because the other alliance to also get 25 points which means that the alliance would net 75 points, which is greater than the 40 they would get if they waited for teleop.
  #35   Spotlight this post!
Unread 08-01-2017, 21:16
Bronze Bronze is offline
FRC #0701 (RoboVikes)
Bronze is an unknown quantity at this point
Good point. However, if you did do this, by employing a strategy that purposefully generates a foul (repeatedly), you are going quite seriously against the spirit of FIRST.
That being said, I am almost certain that the rules intended for autonomous rotors to be 60 points total, not 60 then 40. This would make the tech foul for taking the reserve gear and powering a rotor more of a penalty than the point bonus for getting an auto rotor. (you get 20, they get 25).
  #36   Spotlight this post!
Unread 09-01-2017, 01:56
botster botster is offline
botster is an unknown quantity at this point
I would just like to point out that there has been no rule against all three robots placing their gear on the close spring. That would make scoring three gears considerably easier and faster than having robots drive to the far side of the airship, turn, and then place their gear.
  #37   Spotlight this post!
Unread 09-01-2017, 02:10
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Interesting idea, although I'd definitely check the Q&A for legality.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #38   Spotlight this post!
Unread 10-01-2017, 18:23
Bo8_87 Bo8_87 is offline
Bo8_87 is an unknown quantity at this point
https://firstfrc.blob.core.windows.n...amUpdate01.pdf
The team update states that rotors are scored only if they are not previously scored, so I interpret this as a rotor scored in autonomous won't be recounted for teleop.
For each ROTOR turning by period’s T=0,
that’s not previously been scored
  #39   Spotlight this post!
Unread 10-01-2017, 18:49
jlindquist74's Avatar
jlindquist74 jlindquist74 is offline
WOPR Software Integration Lead
FRC #1622
Rookie Year: 1337
jlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant future
From today's Team Update 1:
For each ROTOR turning by period’s T=0, that’s not previously been scored
The red text is new. If it was scored in autonomous, it won't be scored again at the end of teleop. (The 4-rotor bonus, of course, still stands if you get all four turning.)
