Go to Post It's up to veteran teams and mentors to help keep the original spirit of FIRST alive. - It's up to us to make these boards exemplify the FIRST principals in every post. - Ben Mitchell [more]
Unread 08-01-2017, 23:24
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: 2017 Drive Train
Originally Posted by Kevin Sevcik View Post
Point to consider:
6-WD tank (preferably with a COTS shifter) is the fastest, easiest drivetrain to implement and program. Is a mecanum, H-drive, or swerve so much easier to line up that it outweighs the extra practice time you should have with the tank drive? Or the extra practice time with your practice bot because the tank drive is so much cheaper?
Also, a defensive tank bot is going to shove a mecanum or h-drive all over the place. Good luck scoring a gear while that's happening.
Aw man, if only I were still with Texplosion, that last part is a pure gem.
Yeah, don't overthink the drivetrain. You shouldn't need a vertical adjustment for anything. And, if you are off horizontally, build it into a mechanism rather than moving the whole robot. If you are placing a gear, have a way to rotate it or move it side-to-side. If you are a shooter, have a way to rotate your shooter to keep it on target. Put your code into things like that, not into complex drive.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
