Go to Post We never play to lose, or even go easy. We play our best every match. - Paul H [more]
Unread 09-01-2017, 00:16
deltafief deltafief is offline
FRC #1540
deltafief is an unknown quantity at this point
Re: 2017 Drive Train
Originally Posted by Jay O'Donnell View Post
If there was ever a game to not overthink your drivetrain and just build a really simple tank drive, this would probably be it.
Pretty much this if you go mecanum or h-drive you run the risk of getting pushed around a lot as you have to make lots of trips to get gears or fuel
Unread 09-01-2017, 00:29
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
There is a reason that no robot on Einstein has ever had mecanum drive. (2015 is excluded)
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 09-01-2017, 03:04
lgphoneeric's Avatar
lgphoneeric lgphoneeric is offline
FRC #2996 (Cougars Gone Wired)
lgphoneeric will become famous soon enough
So just so some newer teams don't read this thread and think that mecanum wheels are completely useless at holding their own in a game like this, check out this video from 2014. https://www.thebluealliance.com/match/2014arc_qm29
The bright red and yellow robot (us) were running the new vexpro mecanums (before the metal casters oh how we wish they had the metal insert like they do now) and we easily could hold our own in a pushing contest. The key with mecanums is that the center of gravity needs to be as low and as perfectly centered as possible.
So, do a lot of mecanum drives get pushed around, yes. BUT, if they are optimized, can they hold their own against the most pushy of robots, absolutely!
Just something to think about before teams blindly throw it out because they are under the assumption they can be pushed around with minimal effort.
If you have everything under control, something's about to break.
Former FRC Driver, Alumni, Mentor
Unread 09-01-2017, 03:50
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud of
Frankly, in that video I see your robot pushing around other mechanum/omni robots, and using its momentum well to get the occasional hits on the tank drive 'bots. Your driver is doing a great job, within the physical limitations of the system... those limitations are minimized by the low CG & good system engineering, but still definitely there.
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 09-01-2017, 04:43
One was a swerve, one was a mecanum, and the third was a 6 wheel drive. But often times its more about how you drive the robot and how limitations are overcome such as using momentum. I wish I had video of it, but one of the matches during our first regional (which weirdly only a few matches were recorded) we ended up pushing an 8 wheel colson drive across the field from almost a stand still. Can mecanum drives push very often, not really, but should they be eliminated from decision discussion simply because there is a little defense, in my opinion I definitely do not think so because a good drive team with a slick drive train can do surprising things. So ultimately the point I guess I'm trying to get at is just because a drive train doesn't have as much physical grip as another doesn't mean it can't at times match or outperform a technically gripper drive train.
Unread 09-01-2017, 04:52
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Originally Posted by C_4187 View Post
Mecanum vs. Tank?
Mecanum has an obvious mobility advantage, but how much does it really give up in traction/strength? Is it completely outclassed in strength to a tank drive system?
Uness your driving around a football field Mecanums do not give you the agility that people assume you'll get due to congestion on the field. You'll just get caught and stoned by defense.
Unread 09-01-2017, 05:05
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Mecanum vs. Tank?
https://www.youtube.com/watch?v=O_vvVU4OBT4
Just Sayin.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 09-01-2017, 09:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Jpatterson1710 View Post
Butterfly drive, especially shifting butterfly drive, is probably only a good idea for teams that already know what it is and aren't cruising CD for suggestions on drivetrain decisions.
Unread 09-01-2017, 09:38
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
I don't want this to turn into a mecanum vs tank drive thread or an articulated drive vs tank drive thread, but I think the reasoning behind selecting a simple tank drive is more applicable this year than just about any other. An articulated drive might perform better as a drivetrain than a dropped center tank drive. But is it worth investing 2/3 of your weight allowance and 2/3 of your build season getting a complicated drive system working? Or is it better to build something that is robust and reliable, and spend that time on your subsystems and practicing to improve performance?
Unread 09-01-2017, 10:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
In my view, if you haven't built a swerve drive or H drive or mecanuum drive and had your coders code it and your drivers drive it, you really need to stick to tank drive this year.
The practice time you will lose with your robot is just not going to be able to be overcome by the extra features you are imagining you will have.
Finish early. Give your coders coding time and your drivers practice time and your whole team time to iterate and improve your robot. THAT is the way to be playing after lunch on the last day of the tournament*.
Dr. Joe J.
*said the guy who designed his first Swerve Drive for Ladder Logic (1998 season). Chief Delphi won 3 blue banners with CD3. I KNOW that drive trains matter. But driver practice matters more. A LOT more.
Team #88, TJ2
Unread 09-01-2017, 10:12
Chris is me's Avatar
AKA: Pinecone
Disclaimer: Build a tank drive. Please. Just do that. If you are the kind of person who listens to advice on CD to make drivetrain decisions, do that.
That said, there's a pretty reasonable argument for swerve or butterfly drive this year if it's compact. The bumper rules limit intakes since six inches of room on each side of the drive must be backed by bumper - leaving more space for various omnidirectional drives. Lining up at the peg, goals, or human loader could theoretically be faster using a strafing drivetrain. And the full field sprints lend themselves well to butterfly style drivetrains.
But I mean, if you haven't considered these drives and built prototypes long before reading this post, it's too late, and the possible small advantage they could give your team is more than offset by the development difficulty. We have a bunch of other tough tasks to do in this game, don't make it harder than it has to be.
Unread 09-01-2017, 10:22
pfreivald's Avatar
AKA: Patrick Freivald
Exactly. We built a swerve off-season and they are a LOT of fiddly work to get them to function just as you want them. Ours looks fantastic, and performs great--and we may very well just go with a 6 CIM shifting tank-type (WCD) this year.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 09-01-2017, 10:23
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
It seems to me that people are far overestimating how hard it will be to deliver the gear. The (horizontal) margin of error is 6 inches. That's (approximately) the width of the gear. Because the hook is spring loaded, you have even more leeway, not to mention that the place you have to deliver to is directly in front of your driver station. I'd argue it was harder to line up with the chute in 2015. If your driver really can't do it, just put a camera on the robot and use that to align, but don't build your drivetrain around this particular challenge.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
Unread 09-01-2017, 10:48
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by Southpaw View Post
Our team has thrown around the idea of using h-drive as a less complicated mechanum system.
From a design and build perspective, H-drive is by far more complicated than mecanum drive.
The movement is near-identical to mechanum and debatably easier to build.
PLEASE read the advice posted by experienced Chief Delphi members. If your team has not yet designed and built a holonomic drive system, week 1 of build season is not an ideal time to start.
In my experience, a field-centric holonomic drive is the easiest robot to learn to drive. Mecanum provides a good trade-off between complexity (2 extra gearboxes, a bit of learning to program) for increased maneuverability. It's also the closest you'll get to a COTS solution. Any other drive really needs to be developed in the off-season.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 09-01-2017, 10:55
pfreivald's Avatar
We did straight mecanum for two years, switched to octocanum for a few years, did mecanum again for Recycle Rush. I've never had a student programmer who couldn't fully program a mecanum drive exactly like a 3rd person shooter in at most an afternoon.
There's this myth that mecanum is hard to program. It just isn't. (It's also incredibly easy to build. Just direct-drive four wheels off of appropriate gearboxes, and voila.)
That said, straight-up mecanum will be a mistake this year. The parallels to Ultimate Ascent say defense will be *huge*, and mecanum drives don't do a good job powering through defense.
Team 1551
I write books, too!
