Go to Post To have respect for the process you are in right now, respect the knowledge around you by using it to your full advantage. - Scott Ritchie [more]
Unread 09-01-2017, 00:17
andrewytiger andrewytiger is offline
FRC #3929
andrewytiger has a little shameless behaviour in the past
QUESTION ABOUT LIFTS
Are pilots allowed to lift the lift to desired height even before the robot places a gear on it? For example, would I be able to lift it to two feet and have the robot place the gear on it while it's in that position?
Unread 09-01-2017, 00:24
niklas674's Avatar
niklas674 niklas674 is offline
Mecanum+drive=A bad idea
FRC #0701 (Robovikes)
Team Role: CAD
Rookie Year: 2015
niklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of light
Re: QUESTION ABOUT LIFTS
If you look hard enough youll find at least two other threads about this...
https://www.chiefdelphi.com/forums/s...hreadid=153116
My views do not represent the views of my team
