Go to Post No, I'm not a Superhero...I'm a FIRST Mentor. Common Mistake. - Mr. Van [more]
Unread 09-01-2017, 00:33
LogicParadox LogicParadox is offline
FRC #5754 (Brooks Academy Robotics (BAR))
LogicParadox is an unknown quantity at this point
What are the most desirable attributes top seed teams are looking for in a robot?
What are the most desirable attributes top seed teams are looking for in a robot? In otherwords, what are the most important attributes and/or action a robot would need to have/preform to be chosen by the top 8 teams. It is within the power of my team to create a bot that can do everything, would it be better to stick to one attribute/action vs doing it all?
Unread 09-01-2017, 00:40
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Re: What are the most desirable attributes top seed teams are looking for in a robot?
I'm of the opinion that the really good teams want robots that do one thing well. If you can do one thing well and demonstrate that consistently in quals then they have one less thing to focus on during elims.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 09-01-2017, 00:58
Isaac Ash's Avatar
Isaac Ash Isaac Ash is offline
Business Captain
FRC #4536 (MinuteBots)
Isaac Ash is on a distinguished road
It is ABSOLUTELY better to focus one one/two things rather than trying to everything, especially if you have limited resources (that includes experience). You can check out Karthik's latest seminar on effective FIRST strategies: https://www.youtube.com/watch?v=sJOfH-lomEQ
As he says, a jack of all trades is master of none, and it is always better to do a few things at a "10" level than to do a bunch of things at a "5" level. Most alliance captains want robots that find a niche and do that really well, so they can build a good, well rounded alliance.
minutebots.org
2014, 2015, 2016 10,000 Lakes Regional Finalists
(Thanks 2705, 3202, 2052, 4198, 2846, and 5996)
2014 Galileo Division
2015&16 Carver Division
Unread 09-01-2017, 01:00
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Prefacing with we've only had 2 days of analysis...
Powerful drive/good drivers. In games like this, may teams (such as ours) are less likely to pick mecanum robots that can't do anything other than play defense.
Climbing is nice to have, since you're missing out on 50 points for every robot that can't do it.
As always, if you do something valuable that few others can do, that's an easy way to get picked quickly.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 09-01-2017, 01:54
AcidWombat AcidWombat is offline
FRC #0971
AcidWombat is an unknown quantity at this point
coming from what we would want as a second pick, we are looking for just fast, efficient gear manipulation, competent handling (no mechanum/omnis pls) and a climber.
this is because higher level teams this year are going to focus on large volume boiler scoring, and all that they want is a little help with gears, and the elims bonus of a climb just makes you that more attractive.
Unread 09-01-2017, 02:04
Would you say a static gear manipulation system and a climber be better then an active gear manipulation system with a climber?
Would you say an active gear manipulation system is better than having a climber with a static gear manipulation system?
Unread 09-01-2017, 02:10
Please note: I do Not include a high shooter when I say "doing it all". My team doesnot have any experience with shooters.
Unread 09-01-2017, 02:24
nardavin nardavin is offline
FRC #2403 (Plasma Robotics)
nardavin is on a distinguished road
I would wager that most top seed teams will be looking for robots that are very good in the captain's specialty as a first pick. This would take a lot of the pressure off of the captain to carry their team to achieve the would-be RP conditions for the bonus points (100 points for all 4 rotors or 40 points for 40 kPa).
For second pick they will probably want a solid defense bot, as there's not much space for all 3 robots to move easily around the airship.
For both first and second pick, I bet that climbs will be a must-have. That's a very easy 50 points per climbing bot.
Team 2403: Plasma Robotics
Member 2014-2017, Head Programmer 2015-2016, Leadership Team 2016-2017, Co-President 2017
Unread 09-01-2017, 02:30
RoboAlum RoboAlum is offline
Mickey D's
FRC #4841 (Optimal Robotics)
RoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the rough
I would say a small robot that holds its own on defense can do gears in auto and teleop consistently and can hang quickly and consistently
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 09-01-2017, 02:38
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
While I'm not on a top seed team, in my mind, the active or static state of your mechanism does not matter as much as effectiveness of that mechanism.
Unread 09-01-2017, 02:44
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
What you described would very likely BE a top 8 bot at most Regionals.
Unread 09-01-2017, 02:49
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant future
Scoring lots of gears quickly and climbing reliably is all anyone cares about. How you do it doesn't matter.
Mickey D's
Well upon breaking down the game its not hard to do especially with the resources teams have.
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 09-01-2017, 02:57
Registered Muser
I agree that neither of the game objects are extremely difficult to manipulate if you dedicate yourself to one or the other, but any team that can consistently place a Gear in auto, three Gears in teleop and climb will have a high seeding robot in most Regionals. Many teams would do well to aim for this goal and focus on achieving it.
Unread 09-01-2017, 07:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As always, consistency and speed (that is, rate of scoring), and the ability to score despite being defended against, in about that order.
As there will be very few 'bots capable of 12 gear cycles (at least if it means zipping to the far end of the field and back as well as the hang) by themselves, I figure that winning alliances (at least in early weeks) will consist of two gearbots and one high goal shooter. The good news is that the fuel vs gears poll seems to indicate that the teams are breaking somewhere close to that ratio. In later weeks, as the number of gears a single robot can place (at the high end of competition) reaches or at least approaches 12 (probably through floor pickup and forcing fumbles), hanger bots which can at least harvest for the shooter, and preferably also shoot fast, will find more use.
