Go to Post Brandon, it's not an issue... but the fortune cookie thing that you get when you give someone rep is a little creepy... - Beth Sweet [more]
Unread 09-01-2017, 07:37
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
Lifting Gear Out of Robot
Hey CD,
Quick question: I've been looking at the rules, and I don't see anything explicitly forbidding the pilot lifting the gear out of the robot once it has the gear hooked. Is this allowed?
Unread 09-01-2017, 07:41
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Lifting Gear Out of Robot
As of now yes
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 09-01-2017, 07:44
Rookie Year: 2015
Do you expect that to be changed?
Unread 09-01-2017, 07:45
no
Unread 09-01-2017, 07:46
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
I'm sure that will be one of the first questions asked when Q&A opens
Unread 09-01-2017, 08:52
RobotsQ RobotsQ is offline
FRC #1155
RobotsQ is an unknown quantity at this point
This is easily the fourth thread of the exact same topic, try reading through the other three.
I'll give you a synthesis: There is nothing explicitly forbidding it right now, but Q+A opens on Wednesday and due to FIRST's cautious nature and requirement to stick closely to industry standards on machine-human interaction (for insurance reasons) it is more likely than not that this will be outlawed in the coming days. At the very least we'll be getting a clarification.
Sent from my iPhone using Tapatalk
Unread 09-01-2017, 09:08
Chris is me's Avatar
AKA: Pinecone
I'm of the opinion this is going to stay legal. There's a reason the scoring peg is a spring and that it is indirectly operated by a human several feet away from the robot.
Unread 09-01-2017, 09:41
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Time is critical. It might take a couple of seconds for the human to verify the gear is loaded, then lift it out of the way. The robot is idle during this time.
If you can just slam the gear on the peg and instantly drive away, you can save those precious seconds.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 09-01-2017, 09:55
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Not necessarily. Our team was talking about this, if we have some sort of visual indicator on top of the bot (like a led ring) that turns green as soon as the gear is good to go, the pilot yanks up hard, and the bot drives away. Shouldn't take more than an extra second than just leaving the gear there.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 09-01-2017, 10:18
fearxzombie's Avatar
fearxzombie fearxzombie is offline
AKA: Gabriel McMillan
FRC #5495 (Aluminati)
Rookie Year: 2016
fearxzombie is an unknown quantity at this point
I was going to ask the same thing, I was thinking it would not work due to physical constraints. But if you can figure it out, by all means use it as an advantage.
~Gabriel McMillan
FRC 5495
Aluminati
CAD and Building
Unread 09-01-2017, 11:19
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I expect it to be made illegal, or the Pilots will have to wear gloves. There is a non-zero probability that a robot will yank the post down while being hit by a defender, giving a pilot rope burn.
It seems like pilots will want gloves regardless - accidents happen.
If the rules change, how they constitute that a robot has backed 'far enough' away to allow for safe retrieval will inevitably be the next topic of discussion - so hopefully a few Q&A posts will have some sort of multi-faceted question.
2017 Scoring Model
CAD Library | GitHub
Unread 09-01-2017, 11:24
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
the lift has a handle, so rope burn should not be a concern for the Pilot.
Unread 09-01-2017, 11:54
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Also the "post" is actually a spring. So it will be significantly harder to "yank the post down" than you might expect.
I don't see why this would be made illegal. Whether it's a good strategy or not is a different question.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-01-2017, 19:12
NAP17 NAP17 is offline
FRC #4361
NAP17 is an unknown quantity at this point
Post Rope Rules
When a robot is putting a gear on the spring can the pilot pull the rope to the ship at the same time to help the robot?
This is for strategy
Unread 09-01-2017, 19:19
NShep98's Avatar
NShep98 NShep98 is online now
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Re: Rope Rules
S07. Keep your hands “inside” the vehicle at all times. During the MATCH, the PILOT may neither
A. contact ROTORS,
B. contact DAVITS, nor
C. reach outside any PORT.
Violation: YELLOW CARD
No
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
