Go to Post I openly admitted to using IE at robotics last year and recieved a major lashing for such blasphemy. Then I downloaded Chrome. - jwallace15 [more]
Unread 09-01-2017, 09:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: What are the most desirable attributes top seed teams are looking for in a robot?
Originally Posted by LogicParadox View Post
Would you say a static gear manipulation system and a climber be better then an active gear manipulation system with a climber?
Would you say an active gear manipulation system is better than having a climber with a static gear manipulation system?
Speaking from both sides of alliance selection... It does not matter at all what type of mechanism you build. It only matters how effectively you can execute it.
To answer the initial question: a strong scoring ability for a 1st round pick (1 auto GEAR, 4-6 teleop GEARs or equivalent FUEL) and a reliable climber. For second round picks: a smart drive team that can play strong defense without drawing fouls (harder than it sounds) with the ability to score at least 1x gear in Auto or Teleop and climb. Paramount to both picks will be the ability to navigate a heavily FUEL-contaminated field.
Side note: given bumper rules, FUEL and GEAR contamination of the field is going to be a serious consideration.
