Go to Post Or you could go to the Waterloo or Greater Toronto regional, walk up to anyone in their pit, and ask. You may end up feeling like you asked for a sip of water and ended up soaked by a fire hose, but you won't walk away disappointed. - Richard Wallace [more]
Unread 09-01-2017, 06:35
ProfessorAlekM ProfessorAlekM is offline
FRC #6190
ProfessorAlekM has a little shameless behaviour in the past
Robot will not drive when using UDP in autonomous
Hello!
I've wrote UDP code to communicate with a beaglebone from the roboRIO, however when the I put on autonomous mode and the UDP is used none of the motors work, and when I change back to teleop I still can't control anything.
Here is the code:
public class Robot extends IterativeRobot {
	//Beaglebone Communications
    DatagramSocket serverSocket;
    byte[] receiveData;
    byte[] sendData;
Code for robot init
try {
			serverSocket = new DatagramSocket(9876);
		} catch (SocketException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
    	receiveData = new byte[1024];
        sendData = new byte[1024];
public void autonomousPeriodic() {
    	//Receive Data
        DatagramPacket receivePacket = new DatagramPacket(receiveData, receiveData.length);
        try {
			serverSocket.receive(receivePacket);
		} catch (IOException e) {
        String sentence = new String( receivePacket.getData());
        System.out.println("RECEIVED: " + sentence);
        InetAddress IPAddress = receivePacket.getAddress();
        int port = receivePacket.getPort();
        //Return data
        String capitalizedSentence = sentence.toUpperCase();
        sendData = capitalizedSentence.getBytes();
        DatagramPacket sendPacket = new DatagramPacket(sendData, sendData.length, IPAddress, port);
        try {
			serverSocket.send(sendPacket);
        switch (sentence) {
        	case "a":
        		myRobot.tankDrive(0.5, 0.5);
        	break;
        	case "b":
        		myRobot.tankDrive(0,0);
        	break;
        Timer.delay(0.005);
Thanks for any help!
Unread 09-01-2017, 09:40
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Robot will not drive when using UDP in autonomous
Originally Posted by ProfessorAlekM View Post
Hello!
Here is the code:
    byte[] receiveData;
    byte[] sendData;
Code for robot init
try {
    	//Receive Data
        try {
        //Return data
        try {
        switch (sentence) {
        	case "a":
        	break;
        	case "b":
        	break;
        Timer.delay(0.005);
You may be running into a Java subtlety here.
boolean eq = ("abc" == "abc");
System.out.println(eq); // false!
I'm not entirely sure, but it may be the same problem in your switch statement. Try using String.equals in an if-else instead.
Otherwise, use the debugger to verify that sentence contains the "a" or "b" you need.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 09-01-2017, 09:47
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
From the documentation for DatagramSocket.receive():
This method blocks until a datagram is received.
This means it will wait for information from the beaglebone before continuing with your user program. This waiting causes the motors to not be updated fast enough. I see two options to solve this:
We have a NetworkTables build for the beaglebone on the WPILib maven server (armhf):
http://first.wpi.edu/FRC/roborio/mav...NetworkTables/
Take a look at this document for more information:
http://wpilib.screenstepslive.com/s/...client-pc-side
Unread 09-01-2017, 09:50
AKA: אוסטין
That looks ok to me. Take a look at this Oracle document: https://docs.oracle.com/javase/8/doc...gs-switch.html
Unread 09-01-2017, 13:20
FRC #6190
As it turns out, the string being sent was not just a single letter, It was a single letter with another 1023 filler characters. When I made it split up the string based on spaces the switch function worked.
Also thank you for the networking table content, I will look into setting up a seperate thread because the robot "jitters" and moves a tiny bit every time a udp packet is received!
Unread 09-01-2017, 14:23
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is on a distinguished road
The beauty of NetworkTables is that they've dealt with the threading issues for you already. If you aren't familiar with/comfortable with multithreaded programming in Java, tread carefully on the UDP route!
