My love spiders out in a web of emotions when I think of you.
Unread 09-01-2017, 10:44
Robojacks4674's Avatar
Robojacks4674 Robojacks4674 is offline
Lead Strategist
AKA: Brock
FRC #4674 (Robojacks)
Team Role: Tactician
Rookie Year: 2016
Robojacks4674 is an unknown quantity at this point
Can the Pilot do anything during autonomous?
I'm actually curious, since the following pieces of information are contradictory...
4.1 [Periods]
...The first period, called AUTO, is the first fifteen (15) seconds of
a MATCH in which ROBOTS operate without any DRIVE TEAM control or input.
This shows that the pilot IS indeed, technically a member of the drive team.
"To start ROTOR 1, the PILOT places the GEAR..."
This clarifies that to start a rotor, the pilot must place the gear (such information was gathered in Figure 3-12)
This, combined with the other presented information, shows that, in order to get the additional 20 points for a rotor to spin, the pilot must place a gear, therefore, a member of the drive team is technically interacting with field elements during autonomous.
"The only difference between science fiction, and science, is time." -Dean Kamen
Originally Posted by cadandcookies View Post
You (sic) intake should command that the game pieces it touches enter your robot, not lightly suggest that they do.
2016 (Stronghold) -> Lead Scout, Strategist, & Drive Coach
2017 (Steamworks) -> Lead Strategist, Lead Scout, & Drive Coach
Unread 09-01-2017, 10:47
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: Can the Pilot do anything during autonomous?
Correct, but Section 4.1 only says that "Robots operate without any Drive Team control or input", not that Drive Team members (specifically here, Pilots) can't score without controlling the robot.
Unread 09-01-2017, 10:50
Bryce Clegg's Avatar
Bryce Clegg Bryce Clegg is offline
FRC #3196 (Team SPORK)
Bryce Clegg is on a distinguished road
The drivers would be interacting with robots by controlling it during auto, which is prohibited, while a pilot would be interacting with game pieces. Also, since placing the gears is necessary for auto gameplay, that means the pilot is in the right. Using that, I guess that also means human players can interact with the feeder stations and game pieces during auto.
Deans List Semi-Finalist 2016
"I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." - Woodie Flowers
Unread 09-01-2017, 10:55
Lead Strategist
AKA: Brock
Rookie Year: 2016
What about the grey area with the rule about when the pilot can interact with a received cog (I believe it is G23, I am in class right now and can't make a rule snippet)
EDIT: Rule G26
Unread 09-01-2017, 11:03
Back after 4 years off
FRC #5279
See H08, they can move things around, but game pieces can't enter the field.
Originally Posted by H08;
GAME PIECES through LOADING STATIONS only. ALLIANCES may only deliberately cause GAME PIECES to leave an ALLIANCE STATION or LOADING LANE
A. during TELEOP,
B. by a HUMAN PLAYER or DRIVER, and
C. through a LOADING STATION slot.
Violation: FOUL per GAME PIECE. If strategic, RED CARD.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 09-01-2017, 11:10
Lead Strategist
AKA: Brock
Rookie Year: 2016
But, TELEOP and AUTO are different. Therefore, still prohibited.
Each MATCH is divided in to two periods. The first period, called AUTO, is the first fifteen (15) seconds of
a MATCH in which ROBOTS operate without any DRIVE TEAM control or input. During this period,
ROBOTS attempt to deliver preloaded GAME PIECES (and PILOTS race to install delivered GEARS),
retrieve additional GAME PIECES, and cross their BASE LINE before the start of the next period.
TELEOP is the second period in a MATCH and is two minutes and fifteen seconds (2:15) long. During
this period, DRIVERS may operate ROBOTS remotely to retrieve and deliver GAME PIECES, defend
against their opponents, and climb their ROPES to prepare for the impending departure of their AIRSHIP
after the MATCH.
TELEOP and AUTO are different periods, and also the PILOT is neither a HUMAN PLAYER nor DRIVER, just a member of the DRIVE TEAM, similar to the DRIVE COACH, who cannot interact.
Unread 09-01-2017, 11:50
mypie4050's Avatar
mypie4050 mypie4050 is offline
AKA: Micah Young
FRC #4050 (Biohazard)
mypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nice
Note that the manual says that drivers are not permitted to interact with robots, not field elements. It is obvious that pilots would need to interact with the gears to get a rotor turning in AUTO, so what you are referencing is not a contradiction, more just a misinterpretation of what a member of the drive team is permitted to do.
Unread 09-01-2017, 12:02
Lead Strategist
AKA: Brock
Rookie Year: 2016
Even then, the other posts. there is still some grey area.
Unread 09-01-2017, 12:08
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
EDIT: Rule G26
G26 states simply "Any GEAR transferred to a PILOT during the MATCH must be done so via a LIFT." Again, the PILOT is not controlling a robot, and it does not say that a PILOT cannot use a LIFT during autonomous (and in fact they have to in order to score the autonomous rotor points), so I don't see any gray area for confusion.
Unread 09-01-2017, 12:09
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
The maximum of the grey area would be if the PILOT pulls the GEAR from the ROBOT using the LIFT during AUTO. Surely, if the ROBOT places the GEAR, and removes all contact between the ROBOT and the GEAR so the GEAR is only contacted by the LIFT and then the LIFT is manipulated by a PILOT then there is no DRIVE TEAM to ROBOT interaction.
At most the manual may prohibit the PILOT from operating the LIFT to remove a GEAR from a ROBOT. But, if the ROBOT is not in contact with a GEAR on the LIFT then the PILOT is free to operate the LIFT.
Caps for rule book emphasis/consistency.
This is the strictest interpretation I could envision. The intent of the rule is to not allow human input to control the robot. So, practically speaking, GDC will probably allow the pilot to operate the lift to remove a gear from the robot so long as the pilot doesn't supply a control signal to the robot in the process.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 09-01-2017, 12:14
Lead Strategist
AKA: Brock
Rookie Year: 2016
Indeed. Sorry to everyone else for my lack of clarification but this is where I was leading. There was another post on Saturday about a potential issue with when a pilot can operate a lift, and if the robot is still in contact, would that be considered robot to human interaction.
That was the only other thing I was confused with, and perhaps in the weekly team updates, some of the language will be cleared up.
Unread 09-01-2017, 12:24
Chris is me's Avatar
AKA: Pinecone
I honestly dont' get the ambiguity here. Of course they can. This is obvious because otherwise scoring gears in autonomous would be impossible, but the wording of the rules supports that too.
The DRIVE TEAM is not prohibited from "interacting" in a general, broad sense. The full rule text is "ROBOTS operate without any DRIVE TEAM control or input". The PILOT is not operating the ROBOT, obviously. They are neither controlling nor inputting commands to the robot. Control or input
H08 doesn't come into play at all either, because the game pieces in question are in the field of play. They are not in the ALLIANCE STATION.
I actually can't find the word "Interacting" in the rules anywhere in this context. That isn't the wording of the rule. The rule is "ROBOT operates ... control or input". This isn't ambiguous. There's nothing to see here.
The PILOT is not prohibited from doing anything in autonomous excluding what they are prohibited from doing the entire match and using the reserve gear.
Unread 09-01-2017, 12:54
FRC #6357
There is an ambiguity, though not related to the OP.
Picture a robot that preloads a gear and 10 fuel, delivers the gear to the boiler facing side of the airship, then backs up to deliver fuel to the boiler. Suppose the reversing to the boiler is initiated by a state change on a contact switch indicating the gear is present. When the gear is removed, the robot backs up.
In that scenario, is the removal of the gear providing a control signal to the robot? Q&A shall decide, I suppose.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 09-01-2017, 14:15
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
4.1 states "... and PILOTS race to install delivered GEARS" during auto.
Unread 09-01-2017, 14:24
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
if our gear delivery required it to be lifted out, we would do this. It is not a crazy idea. The question certainly needs an answer from the GDC.
I would also argue that the program could be such that the state change of the gear being removed from the sensor is not necessarily a control input, but still may be an indirect input. The argument would go as such.
  1. The program is periodically checking for the presence of the gear
  2. if the program detects that there is no gear, the autonomous program continues along a different logic path (driving away vs not driving)
  3. the robot has no way of knowing how or why the gear is not there
it's not a good argument, but it is an argument. I think it could still be ruled as indirect control which is still not allowed. in that case, we'd just have to go off time and hope.
