Go to Post Kids should already be motivated to build the best robot they can, and learn as much as they can. They shouldn't need extra incentives. - Matt382 [more]
Unread 08-01-2017, 18:55
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Re: Point of reserve gear?
Originally Posted by Dibit1010 View Post
I'm confused- can a pilot get a gear from a bot and put it in the 1 gear slot to get the big rotor turning for auto points? I looked through the manual and didn't find anything against it but it seems odd that it would be allowed
I'm not quite sure why that seems odd to you. From a scoring point of view, the big rotor is no different from the three smaller rotors. Since the big rotor is "rotor 1," it must be the first rotor started by an alliance, and if a robot delivers a gear in auto, the pilot should insert it there for auto points.
--Jacob
Illinois FTC FTA
Unread 08-01-2017, 19:18
Yep. And they can't use the Reserve gear to do that in auto, so it has to be a robot-delivered gear.
Unread 08-01-2017, 19:28
aidanl78 aidanl78 is offline
FRC #0078
aidanl78 is an unknown quantity at this point
Originally Posted by Lil' Lavery View Post
Situation A (team takes foul to place reserve gear in autonomous):
60 points (autonomous rotor) - 25 points (tech foul) = 35 points
Situation B (team places reserve gear in tele-op):
40 points (tele-op rotor)
40 > 35
Along with you still being down five points, there are also rules in which you get a penalty if you break a penalty for strategic reasons so instead of a 5 point difference, you bring that difference to 30 points and run the risk of yellow and eventually red cards
Unread 08-01-2017, 19:31
Not on that one. There's no "strategy enhancement" on A05. There's the "Repeated" part of T03, but that's a straight yellow if employed.
Unread 08-01-2017, 19:49
Andhika's Avatar
Andhika Andhika is offline
FRC #6405 (The EntreBots)
Team Role: Student
Andhika is an unknown quantity at this point
Sent from my iPhone using Tapatalk
Yes, it is allowed I'm pretty sure. This would encourage autonomous function for teams since a gear being placed in Rotor 1 would earn 60 match points instead of 40 from a pilot placing in the reserve gear as tele-op starts.
Unread 09-01-2017, 11:32
Evan G Evan G is offline
FRC #1533
Evan G is an unknown quantity at this point
According to rule A05, a pilot cannot remove the reserve gear from it's slot in autonomous. However, the reserve gear is a free 40 points in teleop mode.
Unread 09-01-2017, 11:51
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Are you sure? T03 implies otherwise:
Originally Posted by YeOldeManual
Egregious or repeated violations of any rule or procedure is prohibited.
Violation: The Head REFEREE may assign a YELLOW CARD as a warning, or a RED CARD for DISQUALIFICATION in MATCH.
I don't think they have to call our the "enhancement" to call it.
Unread 09-01-2017, 11:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The reserve gear effectively levels out scoring on the final two rotors. It means that a single bot getting 1 auton & 5 teleop gears in the match is the same score as that bot getting 1 auton and 6 teleop gears. It means that an alliance of robots who are individually capable of scoring 4 teleop gears each can find something else to do to supplement their match score.
Since there is no verbiage in the manual which states the reserve gear could be taken away for DCMP/WCMP events, expect it to stay. Using it smartly is strategically important, since it gives ball-focused alliances more options for selecting or being selected by gear bots.
In other words, before stuffing it in slot 1 of the first-available rotor, double-check with the gear bots on your alliance.
2017 Scoring Model
CAD Library | GitHub
Unread 09-01-2017, 12:05
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Originally Posted by JesseK View Post
Using it smartly is strategically important, since it gives ball-focused alliances more options for selecting or being selected by gear bots. In other words, before stuffing it in slot 1 of the first-available rotor, double-check with the gear bots on your alliance.
I don't understand why you shouldn't just put it in the slot as soon as teleop starts. In what case would there be an advantage to waiting till later in the match to use it? Or not using it at all? I can't think of any reason not to.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-01-2017, 12:29
JesseK's Avatar
FRC #1885 (ILITE)
Things in a match never go as planned. As a coach, I can easily tell the pace of a match by determining when the 2nd rotor is activated. If robots can't do the first 2 rotors on their own in a reasonable time, we have to make a decision on whether or not to go for the third rotor.
If by some miracle 2 rotors are done in autonomous then I would use the 3rd rotor as the gauge for match pace - and if things go poorly then we'd finish the 3rd rotor with the reserve gear.
As I see the game now, I fully suspect the reserve gear will always be placed on the 3rd rotor in the matches I coach - regardless of when in the game that happens.
At the highest levels of play, I agree that holding back the reserve gear has diminished value.
2017 Scoring Model
Unread 09-01-2017, 13:01
Ari423's Avatar
FRC #5987 (Galaxia)
Another idea would be to make a non-powered signaling device to relay the info to the coach of how many gears are in the uncompleted gear train. This way the coach knows exactly how many gears are done and there's no chance that the pilot will forget to place the reserve gear. IIRC all members of the drive team are allowed to use non-powered signaling devices, and there's no rule they can't attach them to the railing so the coach can see them without being constantly held.
2013: Programmer
Unread 09-01-2017, 13:25
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
As pointed out by a co-worker, it may be that FIRST is tired of seeing 0-0 match scores. This way, there won't be any shut-outs (unless someone really screws up)
Former Mentor Team 1771
Former mentor Team 4509
