Go to Post 22 motors? Challenge Accepted. - gyroscopeRaptor [more]
Unread 19-04-2003, 04:44
Brian Yip Brian Yip is offline
#0114 (Eagle Strike)
Brian Yip is an unknown quantity at this point
Send a message via ICQ to Brian Yip Send a message via AIM to Brian Yip
Lightbulb Give some comments to 114's animation
Hi everybody,
My name is Brian and I'm the chief animator of 114. Just like other animators, I spent a lot of time on the animation. I would like to hear some feed backs from other people.
Please give me any comments you have. I don't care if it's positive or negative. Go to http://www.lahsrobotics.org
and click on 2003 animation.
Brian
one fourteen Chief animator
Unread 19-04-2003, 10:32
xavior06's Avatar
xavior06 xavior06 is offline
#0075 (RoboRaiders)
xavior06 is an unknown quantity at this point
Send a message via AIM to xavior06
awesome animation, i really like the reflections, textures and lighting.. wow. the robot movement seemed very realistic. awesome.
Unread 19-04-2003, 10:59
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Technically it's superior as always from you guys but there is nothing that really compels me about it. What you did last year clearly explained the bebefits of FIRST. THis just showed a robot.
Unread 19-04-2003, 11:19
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Wow, amazing job with the modeling and animating, most people's box falling didn't look that good, but you guys made it look real. All of the actual animating was awesome. I agree with Koko that it didn't show as much of the meaning of FIRST. It shows the robot and advance to space exploration, but it doesn't clearly show the growth to that. The sound was a little slow too, something more upbeat would keep the attention even more. But other than those things, it was an amazingly well done animation. Great job!
Chopsaw? Chopsaw.
Unread 19-04-2003, 11:34
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
No atmosphere on mars should mean flags don't wave in the wind.
If you guys remember the opening scenes of Independance Day, they did the same thing - as the aliens passed the moom, the deep ambiant noise of their inter-galaticary space engines many the theater speakers roar and the sand on the moon shake - meanwhile, sound and pressure have to travel through some kind of medium, and there's not a lot of that in space.
ehhe... sorry... got carried away there.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 19-04-2003, 12:51
Chris Nowak Chris Nowak is offline
Soudeska?
#0074
Chris Nowak is an unknown quantity at this point
doesnt mars have an atmosphere? I thought it had sandstorms and such, doesnt it
MSN Messenger - chris_nowak91@hotmail.com
Team 74 - Top Seeded Team in Galileo Division
Unread 19-04-2003, 12:53
Soudeska?
#0074
wow! Extremely impressive!
Unread 19-04-2003, 15:21
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Mars does have an atmosphere. It is very thin (approximately 1% of the density of Earth's atmosphere at sea level), but it is there.
On the Mars Pathfinder experiment in 1997, the lander included a set of "wind socks" - little flags that were mounted on a thin post that fluttered in the wind. Their movements were measured and used to determine the wind velocity at the surface of Mars. So, yes, you can have flags fluttering in the wind on Mars.
As for the animation, it is very impressive. The only comments I would make are definitely in the realm of "tweaks." The lab setup in the beginning, as the robot is coming together, is way too clean. The walls, bench surfaces, cabinet doors, etc are all absolutely pristine. They should be smudged up a bit - add some weathering and texture and signs of a little abuse to them. In the Mars scence, as noted above, you can have flags waving in the Martian breeze. However, the flag is waving way too violently. If the flag is flapping that fast, then you would have a major sand storm blowing around it as well - one so strong that you probably wouldn't be able to see anything else. The rest of the animation is great!
-dave
Unread 19-04-2003, 15:29
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I don't even have to go to your site to remember this animation! This was a great, great animation, I really enjoyed watching it @ the Pheonix Regional. Very realistic and everything. I was speechless the first time I watched it... very nice, keep up the incredible work.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 19-04-2003, 22:29
I agree that the flag is going too fast, relative to the magnitude of the sandstorm. The sad thing is we did not figure that out till the very last hour. One point that dlavery pointed out is "If the flag is flapping that fast, then you would have a major sand storm blowing around it as well - one so strong that you probably wouldn't be able to see anything else." I want to emphasize the Martian environment by adding sandstorm and a windy environment, but I put too much wind to it. Oops. It's definitely something that I can change. I'm surprise that it makes a huge difference though. I thought this is just a tiny thing that is hard to notice. Thanks for pointing that out.
I think our message did not bring out strongly to people. We were thinking that since this year's robotics game has to do with breaking the wall of crates, why don't we make our animation so it's about breaking the barriers to achieve success. We were working on it, but it was lacking of explaining. If there is someone explaining what is happening, the animation will relate to FIRST more. That's definitely something important that we are missing.
Unread 19-04-2003, 22:31
by the way, thanks for giving me these comments. It's very hard for me to see the mistakes we have.
If you see more, feel free to post them.
Unread 20-04-2003, 01:39
FRC #0701 (RoboVikes)
I have to say it was amazing, it received a straight 20/20 for technical and was THE best animation at the wester conference, technically speaking, all scenes were well lighted,textured ,and animation was smooth, i think i met u at the silicon valley regional ( iwas the lead animator for 701 ) , thanks for the tips on ray tracer i am now using those textures to achieve that near photrealism that u guyz have , also like they said : it doesn't have a real meaning like u know.. very clear thing about first. gunn highschool had narraration what is what we'll do next year and it won at LA as well as San Jose
Unread 20-04-2003, 02:43
I remember you!!
Thanks for your feedback. Narrator is very important which our animation is lacking. It will definitely be better if we have a narrator.
next year's animation will be way more competitive. Time management is EXTREMELY important. I'm actually very curious to know how many teams have problems with the 6-week working time. We definitely have a great problem with time. We were thinking of adding motor sounds and crates tumbling sound. but we don't have time.
The trend is very obvious, the quality is improving exponentially. Can't wait to see more great animations.
I love to answer questions and listen to people's opinions. if you have questions, I will definitely answer you. I guess this is the spirit of FIRST.
Unread 21-04-2003, 07:48
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
OMG THAT WAS AMAZING!!!!!!!
Okay, scene by scene here's what was awesome. Textures and lighting on the robot, was amazing. Awesome raytracing and reflections on the metal. There was also a very good camera angles. They were creative and unique.
Mars, was a lot better then our mars. I liked the lighting and the futristic domes for a habitat. I had a very good ending as well. hmmm...How come you didn't win again? Yours was very good.
1 thing I didn't like. This caught my eye on the first viewing of it. In the first laboratory room, the walls on the back are very plain. There is also a poster that says eagle strike, and It kinda sticks out because It's just a little to crisp and clean, and maybe to computer-like. That;s just about the only thing that I could find in your animation that I didn't like.
Your animation was awesome!!!!
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 21-04-2003, 23:47
TIME Was a big issue 4 us as well, although one kid made an x-45 and another made a desk it was all else left 2 me, guess not enough people interested or willing 2 learn , we don't have many people on the team anyways but i am still very happy that they helped me out. i actually did way 2 many camera angles and stuff liek that in the end i had 2 cut some scenes the time fram is 2 short for only a few peolple , i was compositing at like 2 days before the thing was due , next yr i will persuade some of the art class or computer class teachers 2 give flyers so more people join animation!
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
award for regionals Tyler Olds 3D Animation and Competition 13 20-12-2002 18:16
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
2002 Animation Software Jay Lundy 3D Animation and Competition 34 26-02-2002 20:40
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
