Go to Post While grandmothers are pretty cool, I would be hesitant in letting them determine what is and is not a robot. - Kellen Hill [more]
Unread 09-01-2017, 14:20
Re: if you have the correct spring can you test something for us?
There is a hook on the end of the spring to help retain the gear, so a gear can be successfully supported by the very end of the spring, and the spring doesn't bend much.
It is possible for the hook to get turned in the spring though, so the pilots should be checking the hook orientation and correct it as necessary. It can be twisted by hand with a little effort.
P.S.
Added a second photo showing the gear delivery into the cockpit. You can see the hook at the end of the spring (cut off a bit by the photo framing).
ID:	21505  Click image for larger version
