My love spiders out in a web of emotions when I think of you.
Unread 09-01-2017, 12:38
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
G28 Clarification - Air Powered Shooter
My team is discussing strategies for shooting fuel at a high rate. A google search for "Wiffle ball shooter" produces some videos of leaf-blower powered shooter, and we thought this would be a good solution (powered by a legal motor/in a legal fashion) However, there are a couple sticking points. The first, G28:
Originally Posted by G28
Don’t use air to direct/redirect FUEL. ROBOTS may not use forced air to affect the movement
of FUEL that is outside the volume of the ROBOT.
Violation: RED CARD.
A strict reading of the rule would say that this strategy is illegal if the flowing air affects our launched fuel after it leaves the robot volume, as fast-moving air may tend to do. A less strict interpretation (possibly the intention) is that this rule would only affect FUEL units that are either uncontrolled or controlled by the opposing alliance.
The second sticking point is whether using air in this fashion is legal at all. A cursory search of the rules does not explicitly disallow this (as in whether a fan is a pneumatic device )
Thanks for your input. Please let me know if I missed anything in the rules that pertains to this question. We also intend to ask Q&A for clarification/intent when it opens.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 09-01-2017, 12:42
Chris is me's Avatar
AKA: Pinecone
Re: G28 Clarification - Air Powered Shooter
Q&A this for sure, but where is the ambiguity? It says don't use air to direct fuel outside of the robot. That is as straightforward as it gets. You are directing fuel, outside of the robot, using air. This isn't a "strict reading of the rules", it's what the rule means. Can't possibly be legal.
Unread 09-01-2017, 13:04
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Unless you can figure a way to stop the air from the blower to stop at your frame perimeter while allowing the ball to pass through, I'd say it's not legal.
Definitely a Q&A though.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-01-2017, 13:35
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Because the rule allowed for using air on fuel in your bot's volume rather than ban air moving fuel entirely, it is reasonable to assume that the GDC had a reason to make this distinction. I can think of three reasons to use air to move fuel inside your volume
1) A system similar to a drive-up bank tube, to move fuel through a path in your robot, presumably to your shooter.
2) To agitate fuel in hopper to help it find its way to the shooter intake (like a lottery ball machine)
3) To actually shoot the fuel. If this was their intent, they didn't consider the final residual effect of air on the fuel after it left the volume, but perhaps that was an oversight.
Hoping they address this in the first update, rather than have to wait for the A to a Q.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 09-01-2017, 14:12
pmcoburn pmcoburn is offline
AKA: Philip Coburn
FRC #4930 (Electric Mayhem)
pmcoburn is an unknown quantity at this point
Actually, I disagree, at least on the intent of this rule. I think this is trying to prohibit teams from creating anti-aircraft air cannons to shoot opponents' fuel off-target.
Assuming that you aren't sustaining a stream of pressurized air as the ball continues out of the robot, I think it's very reasonable to think that this rule allows a ball to be shot from within the volume of the robot using pressurized air.
-Phil
Unread 09-01-2017, 14:32
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
-Phil
that would be impossible to inspect. what if they are running the shooter with no fuel? does a stream of air come out of the volume of the robot? if yes, then it violates the rule as written. At best, they get an LRI watching that they never play defense during every match.
Unread 09-01-2017, 14:37
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Oh great, now when we drive our robot across the field and create a pressure differential in the surrounding air we'll be penalized.
Unread 09-01-2017, 14:38
AKA: Pinecone
-Phil
If this was the intent of the rule, why would it say "direct or redirect", and not just "redirect"?
I don't mean to make this more black and white than it is, but it's not a very ambiguous rule to me. People have an idea in their head what they think the rule is supposed to be for, and then they decide that something else explicitly prohibited by the rule actually isn't, because it doesn't match that notion.
The rule says you can't direct (or redirect) balls outside of your robot with air. Can you provide an explanation as to how that isn't what an air cannon is doing?
Unread 09-01-2017, 14:39
-Phil
I would agree that the two primary reasons for the rule are:
1) Prevent changing the coarse of fuel shot by your opponent via air.
2a) Prevent a leaf blowing strategy to gather all the fuel on the floor to your own end of the field.
2b) Similarly, blowing the 50 fuel coming out of the hopper that you aren't catching in your bot to your end of the field.
The question is whether their intent was/will be to prohibit air powered shooters.
John Vriezen
Unread 09-01-2017, 14:40
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
good point. That's not "forced air" to a reasonably astute observer, but a fan is. what's the threshold for forced air, and will i need an anemometer in the inspection station?
Unread 09-01-2017, 14:42
s_forbes's Avatar
I think that is the key word. If you think that an air cannon, designed to launch balls, inside of it's robot's volume violates that then I will direct all of our speed controller fans towards your robot in spite.
Unread 09-01-2017, 15:17
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
My reading of the rule stands with many others. If you want to levitate whiffle balls inside the volume of your robot, go for it. You may not, however levitate whiffle balls outside of your volume. I think air cannons will be legal.
Enjoy. https://www.youtube.com/watch?v=9QBk1c5hfhE
I believe the cuts on the ball in the video are different than the FRC game pieces, but somebody should give this a shot - just for fun... or to win.
Unread 09-01-2017, 15:45
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Point of interest - This has nothing at all to do with inspection. This is a Game rule (hence the G prefix), and is monitored by the refs, not the inspectors. From a practical perspective, your robot could be a giant fan (provided it's safe, per R07) and it would pass inspection. But as soon as you turned on the fan to create a small tornado on the field to suck up balls, I imagine the ref's would flag you.
All that said, I think it's clear that the defensive used of forced air is illegal from that rule. As for a shooting mechanism... I won't even pretend to know how it will be ruled. The penalty is pretty rough for it, though, so I wouldn't want to take a chance on it without first getting an iron-clad Q&A response. And as the Q&A doesn't open up for another 2 days, that's too late for me to spend time or energy on pursuing such a design when I have other options that can be prototyped right now for shooting balls.
2016: Lake Superior WFFA
Unread 09-01-2017, 15:51
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
-Phil
I agree that this certainly is what the rule was intended for. They didn't want a repeat of some of the 2013 defense bots that just had a box fan sitting on a drivetrain, especially considering how much of a detriment that form of defense would be to the game overall.
However, just because that's the intention doesn't mean that's what the rule actually says. An air cannon shooter is entirely illegal under this rule, whether that was the intention or not. Maybe FIRST just really, really hates air-based shooters (can't blame them, honestly.)
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 09-01-2017, 16:04
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
continuing with your point of interest. Inspection is the determination that a presented design does not break any rules. We are inspecting that the robot meets all the R rules, and is not likely to break any G rules by design (G04 is the simplest example of one that we look for specifically on the inspection checklist). My point was that if it used for a shooting mechanism, but the shooter had no fuel, would forced air be leaving the volume of the robot? If so, it's illegal. Overextension limited by software is usually fine, but we still notify the head ref that a robot is capable of breaking a rule on the field, and should be watched. That's the best case i can think of for an air shooter. Legal for shooting, but not legal for defense, and the ref will be notified to keep an eye out.
