Go to Post Don't short change your drivers. They really need drive time. - Joe Johnson [more]
Unread 09-01-2017, 14:11
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
if you have the correct spring can you test something for us?
If any of you have the correct spring can you please tell the rest of us
how far on the spring the gear has to be to be supported so it does not bend the spring and slide off?
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 09-01-2017, 14:20
Re: if you have the correct spring can you test something for us?
There is a hook on the end of the spring to help retain the gear, so a gear can be successfully supported by the very end of the spring, and the spring doesn't bend much.
It is possible for the hook to get turned in the spring though, so the pilots should be checking the hook orientation and correct it as necessary. It can be twisted by hand with a little effort.
P.S.
Added a second photo showing the gear delivery into the cockpit. You can see the hook at the end of the spring (cut off a bit by the photo framing).
ID:	21505  Click image for larger version
Unread 09-01-2017, 15:07
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Mark,
You have posted several great pictures of the field. Do you have any other key images you can share? I'm especially interested in the view from the driver stations.
Thanks,
David
Unread 09-01-2017, 15:15
I'm afraid the field in Manchester was pretty crowded for panoramic views from the Driver Station to be of any use.
I had to leave before the field cleared out, because I was driving into the snow storm. As it was it took me 8.5 hours to get home from Kickoff with road closings and slippery conditions.
Here's what the drivers would see if the match had several hundred people in it...
Unread 09-01-2017, 15:34
D.Allred's Avatar
Thanks Mark... Need to check the fire code capacity of that field!
Unread 09-01-2017, 21:37
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
P.S.
Maybe someone already posted about this and I couldn't find it, but could you say if anyone dumped a couple bins worth of fuel in the high goal.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 09-01-2017, 22:14
No one was tall enough (9 feet) to do that, and it only operates during a match.
