Go to Post I am definitely as much a student as any one of the kids on the team. - Hieb [more]
Unread 09-01-2017, 14:04
Heber Hooper's Avatar
Heber Hooper Heber Hooper is offline
Rocktaπ Inkling
AKA: Heber Hooper
FRC #6051 (Rocktaπ)
Rookie Year: 2016
Heber Hooper is an unknown quantity at this point
Exclamation I need some help with any info pertaining to a t-shirt cannon
Any and all to do with code in java, as well as possible schematics to make it like a gatling gun, or anything with the pnuematics, we are bad at pnuematics.
Unread 09-01-2017, 14:13
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: I need some help with any info pertaining to a t-shirt cannon
That$@#question is pretty open-ended. Can you be more specific about what you're looking for?
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 09-01-2017, 14:21
Rocktaπ Inkling
AKA: Heber Hooper
FRC #6051 (Rocktaπ)
Rookie Year: 2016
We are looking to make a t-shirt cannon to fundraise, and we need advice since we are new to handling compression/pnuematics. We also need some help understanding how to code such a t-shirt cannon. We want to make one like 254.
Unread 09-01-2017, 15:11
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Build season probably isn't the best time to do this?
Unread 09-01-2017, 15:17
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Never built one so I can't help you with the code, but are you sure the build season is the right time to be doing this? These are always off-season projects
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-01-2017, 16:01
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you do an advanced search and look for threads with cannon in the title, the first dozen or more are all about T-shirt cannons, and probably a bunch more down the line. Reading them should at least get you to where you have specific questions.
Unread 09-01-2017, 21:59
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
I would expect any code to be very similar to a standard FRC robot, so just look at WPILib stuff . Actuating the pneumatics will probably not use a standard FRC solenoid, but the difficult part of that is more on the design/ electrical end. I'll forward along this post to some of our members that were looking into building one too.
Unread 10-01-2017, 11:02
Rocktaπ Inkling
AKA: Heber Hooper
FRC #6051 (Rocktaπ)
Rookie Year: 2016
Smile Re: I need some help with any info pertaining to a t-shirt cannon
We aren't in build season for our team. Someone at our district office messed up our grant and this is our second year and we don't have enough money built up. We are trying to fundraise for all eventualities next year. Thank you all
