Our gears mesh perfectly!
View Poll Results: Are you planing on using the high or(/and) low goal.
High Goal 128 79.01%
Low Goal 46 28.40%
Multiple Choice Poll. Voters: 162. You may not vote on this poll
Unread 09-01-2017, 16:33
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Low vs. High Goal
Patiently awaiting a Karthik "the results of this poll are terrifying" post
Either way, for one ball cycle to be mathematically more valuable than a gear cycle at every point in any given match,* you'd need to be able to hold 40 points worth of balls. In low goal terms, that's 360 balls, AKA a mountain of balls larger than your robot. In other words, it's impossible to carry a match exclusively with low goals. Knowing the clientele of CD tells me nobody here is thinking about anything besides "How can I solo carry a match?"
*yes, I know you can do both in one cycle. This way of thinking simply dissects the cycle to see which part is more valuable at any given point in the match. I also know that gears have diminishing returns as you place more gears, in addition to a steadily increasing risk/reward tradeoff as the match progresses. The point still stands.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
