Go to Post FIRST is not all about the robot, it's about the experience. Don't sour yours by whining about it later. - StephLee [more]
Unread 09-01-2017, 15:54
JonKiddy JonKiddy is offline
Programming Mentor (Java/C++)
FRC #4930 (Electric Mayhem)
JonKiddy is an unknown quantity at this point
2017 STEAMworks Score Sheet (Calculator)
Hello!
I built a mobile friendly website to do some scoring calculations. Feel free to leave a reply below if you find something wrong as I had to make a few assumptions/interpretations from the game manual. There some other wonderful scoring calculator alternatives already built by others, I thought I'd share mine.
Hosted on GitHub Pages:
https://nicholsschool.github.io/2017-Score-Sheet/
The code is up on GitHub:
https://github.com/NicholsSchool/2017-Score-Sheet
Good luck this year!
Unread 09-01-2017, 16:31
jaredhk's Avatar
jaredhk jaredhk is online now
Tried turning it off and on again?
AKA: Jared Hasen-Klein
FRC #1836 (The MilkenKnights)
jaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud of
Re: 2017 STEAMworks Score Sheet (Calculator)
You may want to look at the thread for my scoring calculator because some people brought up some great points about counting fractions.
Jared Hasen-Klein, Director of Team Operations
MilkenKnights.com | Facebook | Twitter | Instagram | Snapchat
FREE RESOURCES
Unread 09-01-2017, 16:34
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
as i am sure you are aware, there is some debate as to rotors spinning in auto counting in teleop. You''l have to wait for the rule update, but i would have a plan for that. The score would be (60*autorotors + (40*(telerotors-autorotors))) in that case
What are the seconds indicators? time to process the fuel? I like that you count high and low processing time separately.
I was confused by the 1s 5s 10s buttons. maybe change text to +/-1 +/-5 +/-10? There is a symbol for +/- , or you could label the button group. I thought at first it was related to seconds.
It took me quite a few seconds to find the output. Is there room to make the text bigger, or use a javascript transition to flash it when it changes?
there seems to be no way to remove fouls? also fouls allow a negative score.
Lastly, the plural of Fuel is Fuel
That may sound like a lot of criticism, but actually that's a very small bug list. Great work. Very useful! You covered nearly all of the test cases i could even think of.
Unread 09-01-2017, 16:36
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
As far as i can tell, he counted the fractions properly, even across Auto+teleop. I went looking for this specifically. Granted, they should still read your thread as there is good discussion about test cases.
Unread 09-01-2017, 16:45
That thread was very helpful in determining the correct way to count the fractions, including the fuel left over from auto. Thanks!
Unread 09-01-2017, 16:47
Great constructive feedback. Thanks! It took a bit of work to get the calculations correct, especially the left over fuel from auto which still counts as a fractional score.
The README.md file on GitHub makes mention of some of my thought processes regarding some of the issues you brought up.
I'm certainly going to make some changes tonight based off your comments. Much appreciated!
Unread 09-01-2017, 16:58
Changed the modifier buttons to +/-. Good idea!
Fixed the spelling mistake.
Thank you so much for your feedback. I plan on making some more modifications later.
Unread 09-01-2017, 20:38
I made several subtle changes that address nearly everything you listed. I'll wait for an official determination regarding the rotors being double counted at the end of both auto/tele. Thanks for your input.
Unread 09-01-2017, 20:48
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Great updates. If you want to be really clever and are willing to deal with my nitpicking..
Can you make the + and - button on each row change text to show the number to be added and subtracted? Technically when you have the +/- 5 button selected some elements still only adjust by 1 like rotors and baseline.
Thanks for the quick updates. I have a shortcut to it saved in the front folder on my phone. Very well done.
I also are somehow getting NaNs on 1.0.5 on my phone. Only happens on refresh and is fixed if I hit reset
Unread 09-01-2017, 21:39
v1.0.5 had a bug, sorry about that. Trying to do too much at once, overlooked a multiplier that needed to be initialized to 1.
Good idea about the +/-5 and +/- 10 indicators. All set! Take a look.
Unread 09-01-2017, 22:15
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
on a desktop, the margin-top of the #score is wonky. It appears to be this css:
PHP Code:
@media (min-width992px) {
#score {
margin-top1px;
I'd suggest keeping it at -25 (which it seems to be on narrower screens).
I suspect in the end that 40kPa = 1 RP.
I'd also move baseline crossing to the end of auto, since then the basic order between the sections will be the same.
Again, great effort and always improving. Also, in software, the users are not always right
Unread 10-01-2017, 13:59
40kPA now = 1 RP.
I reordered the sections a bit. Good idea!
New:
On a phone, if you tilt the phone to view as landscape you should see the game field (*crosses fingers).
If you're on an iPhone, I suggest you save a bookmark and "Add to Home Screen", it will behave like a real app, kinda.
I'll keep my eye out for a ruling on the number of rotors spinning at the end of auto/tele. And I'll continue to adjust the scoring as necessary as I become aware of changes.
Also:
I don't normally cater to everyone's wishes, but I really liked your ideas! Thanks!
Unread 11-01-2017, 14:58
Score Change: For each ROTOR turning by period’s T=0, that’s not previously been scored, 60 auto, 40 teleop
