My love for you never slides around.
View Poll Results: Are you planing on using the high or(/and) low goal.
High Goal 128 79.01%
Low Goal 46 28.40%
Multiple Choice Poll. Voters: 162. You may not vote on this poll
Unread 09-01-2017, 14:54
Flashback0902 Flashback0902 is offline
AKA: Nathan Lance
FRC #5550 (Broncho Bots)
Flashback0902 is an unknown quantity at this point
Low vs. High Goal
I want to know how many team planning on scoring fuel, plan on using the low goal vs. the high goal.
Unread 09-01-2017, 15:27
Nip Nip Nip Nip is offline
FRC #5805
Nip Nip is an unknown quantity at this point
Lightbulb Re: Low vs. High Goal
Pros to high goal: less fuel per point
cons to high goal: less fuel can be launched per second, wiffle balls are extremely inaccurate, takes more power to launch ball.
Pros to low goal: Aiming is not a problem, fuel can be dumped in low goal much faster, takes less energy to dump balls, chance to overflow enemy alliances recycle bin and it will flow in yours.
Cons to low goal: takes a lot more fuel to score a point so running out becomes a problem, wit that fuel has to be recycled more often.
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
If you watch, 2415 Wiredcats one of the PCH teams used an actuated hood on the top of their shooter. This would change the angle of their shots, giving them the ability of making connections from the fender or the key.
You should be able to do the same thing this year, giving an ability to easily change between goals.
[edit] The hood was never actuated in the match, so perhaps you won't understand what I'm bringing up, but it is the highest aluminum rectangle at the output of their shooter. https://www.youtube.com/watch?v=FExfPKVsQDE
Unread 09-01-2017, 15:46
Gus9r9r Gus9r9r is offline
FRC #2337
Gus9r9r is an unknown quantity at this point
For the 2415 Wiredcats actuated hood, could you post a link for a video of it?
Unread 09-01-2017, 15:57
Done. Thought I had, apologies.
Unread 09-01-2017, 16:12
FRC #1836 (MilkenKnights)
High goal doesn't necessarily mean low thoroughput. The balls are light and small enough that a heavy flywheel, and a multi-ball wide shooter will likely maintain a high ROF.
Unread 09-01-2017, 16:33
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Patiently awaiting a Karthik "the results of this poll are terrifying" post
Either way, for one ball cycle to be mathematically more valuable than a gear cycle at every point in any given match,* you'd need to be able to hold 40 points worth of balls. In low goal terms, that's 360 balls, AKA a mountain of balls larger than your robot. In other words, it's impossible to carry a match exclusively with low goals. Knowing the clientele of CD tells me nobody here is thinking about anything besides "How can I solo carry a match?"
*yes, I know you can do both in one cycle. This way of thinking simply dissects the cycle to see which part is more valuable at any given point in the match. I also know that gears have diminishing returns as you place more gears, in addition to a steadily increasing risk/reward tradeoff as the match progresses. The point still stands.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 09-01-2017, 16:57
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Man I must be missing something here didn't expect that many people to go high. I kinda ruled it out because of how much space it would take to just test out designs.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
Unread 09-01-2017, 16:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
No response, as fuel is (at this point) a low priority. In our discussions with fuel as a high priority, we would have worked on a high goal shooter; it would take 360 fuel to reach 40kPa in the low goal without auto; that just sounds like too much to be able to gather and dump in small loads.
Unread 09-01-2017, 17:23
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm not. This isn't anything like the low bar last year. This isn't a finite scoring resource. This doesn't further restrict your build size in favor of points an alliance partner will frequently already have covered.
Unread 09-01-2017, 17:32
GKrotkov's Avatar
GKrotkov GKrotkov is online now
AKA: Gabriel Krotkov
FRC #1712 (Dawgma)
GKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud of
If you can build a shooter that hits the high goal >33% of the time and doesn't sacrifice ball volume, you're doing better than a low goaler.
Low goals are not very valuable.
Unread 09-01-2017, 18:08
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I think the reason some teams are leaning towards low goals is that, although they aren't worth much, they are easy and quick. If you have a 50 ball hopper and you shoot at 5 balls/s*, it will take you 10 seconds to empty your hopper. Compared to about one second for a robot that just dumps their hopper into the low goal. Depending on how many balls you are expecting on the field and how long you think it will take you to fill your hopper**, that could be a big disadvantage. Combine that with your team's high-goal accuracy percentage** compared to a practically 100% accuracy for the low goal and the fact that it's a lot harder to play defense on a low goal dumper than a high goal shooter, low goal scoring could be pulling equal with high goal. For your team, you may decide it's better to shoot high, but for other teams the right decision may be to aim low.
*Approximate speed the goal drains
**Obviously this is different for each team
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-01-2017, 19:31
evanperryg's Avatar
AKA: Evan Grove
It's a pretty difficult, if completely possible objective that is interchangeable with another game objective, and offers little value compared to other objectives. The only significant differences are, as you pointed out, the lack of a points ceiling, in addition to the presence of a cheap and dirty alternative that may prove to be just as effective, cycle times permitting.
2013
2015
Unread 09-01-2017, 21:23
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
We are trying/designing for the >40 kPA in auto be nice to get RP in first 15 secs...if we do it is a complete other story.
But hey why not try?... the teams all for it.
We had a two ball auto routine laid out in first three build days last season that determined our design...never panned out last year in fact never shot a HG in a game. But designing for that precise/fast midline grab (without a foul) gave us a super fast intake in every competition and solid LG so thats was fine for us.
If successful in HG Auto this season..we will cycle gears/climb rest of the time and relax into gear 10.58 sec gear cycling... going to be interesting, would like to nail this one.
We are settled into an overall design so that's good...ahead of last year in that regard. No practice time last year to speak of.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 09-01-2017, 22:19
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm not arguing it is (or isn't) worthwhile to pursue, but rather that the things that made Karthik "afraid" last year do not apply here.
