Go to Post FIRST: Making women's hair grow, and mens hair fall out. - Ashley Christine [more]
Unread 09-01-2017, 14:00
mentos54 mentos54 is offline
FRC #0247
mentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to behold
Bumper zone clarification
I know this has probably been asked in previous years, but could someone clarify G23 for me? If a robot is climbing in such way that it is parallel to the floor, would it be violating this rule? (The only example given is with the robot being at an angle).
Also, if the entire robot were lifted somehow (for example, if it were to end up on top of another robot), would it be violating this rule? Or would the "base" of the robot be transposed to a flat floor, making it legal (except for the whole on top of a robot part). The only example given is with purely the bumpers being lifted without moving the entire robot.
Unread 09-01-2017, 14:06
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Bumper zone clarification
parallel to the floor just means your robot is at an angle of 0. this is fine.
(updated)
I don't think you'd be violating this rule, but it violates others. G14 specifically.
G14. Don’t climb on each other. ROBOTS may neither fully nor partially support the weight of other
ROBOTS strategically or repeatedly.
Violation: RED CARD.
Unread 09-01-2017, 14:07
nardavin nardavin is offline
FRC #2403 (Plasma Robotics)
nardavin is on a distinguished road
Not sure what you mean, G23 is a rule that limits shooting fuel only to your launchpad. It has nothing to do with climbing.
Team 2403: Plasma Robotics
Member 2014-2017, Head Programmer 2015-2016, Leadership Team 2016-2017, Co-President 2017
Unread 09-01-2017, 14:17
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
G23. Shoot FUEL from your own LAUNCHPAD. A robot may only LAUNCH FUEL while in their own LAUNCHPAD (I.e. at least breaking the plane of the line with their BUMPERS).
I'm not sure how G23 applies to the situations you're describing. I assume you meant to put R23.
R23. BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained between the floor and a virtual horizontal plane 7 in. (~17 cm) above the floor in reference to the ROBOT standing normally on a flat floor. BUMPERS so not have to be parallel to the floor.
None of the situations you described would violate R23. The "floor" in this rule is relative to the robot, so basically the floor is the plane defined by your wheels if your wheels is what would be the lowest points of the robot when sitting on the floor.
Unread 09-01-2017, 14:46
FRC #0247
Thanks, and sorry for saying G23 instead of R23.
Unread 09-01-2017, 15:36
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I can only assume this rule was added because of this incident.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-01-2017, 16:39
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
For those who weren't around when this happened, can you give a backstory to this??
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 09-01-2017, 17:35
Ari423's Avatar
FRC #5987 (Galaxia)
816 and 87 both wanted to cross the same defense and couldn't cross any others. No rule about robots needing to start on the ground. The plan was for 816 to drive forward, cross with 87 on its back, and both of them would get crossing points (because both of their bumpers started fully in the neutral zone and ended in the courtyard). IIRC they didn't make it all the way across but both got reaching points.
2013: Programmer
Unread 09-01-2017, 18:40
Mentos,
To insure everyone understands this, under R23 the Bumper Zone is determined during inspection when the robot is standing on the floor. The bumper zone does not change if the robot changes attitude during the climb.
It is meant to address those teams who want to actually manipulate their bumpers so that they move from the fixed position.
Unread 29-01-2017, 15:52
pagoglia pagoglia is offline
FRC #4203
pagoglia is an unknown quantity at this point
OK. Our robot, including bumpers, is 36 x 40 x 24 tall. When we climb, our robot will be tilted at an angle. while tilted, if someone were to take a horizontal measuremenet along the length of one of the longer sides, a measurement of 40.311 inches would be found - this is also equal to a kitty corner measurement of a long side bumper at rest while the robot is sitting on the ground floor. So are we in violation of the bumper zone rule during the climb or not? Confusing especially when I take into account the Q and A answer to Question 151, where they use the phrase 'transposed on the floor'. Not sure what it all means.....
Unread 29-01-2017, 20:15
You're tilted, but what happens if you suddenly land level on the floor?
Right, you're back to your starting size. Note the exceptions for robots tilting while climbing ropes, etc.
You'd be neither in violation of the volume nor in violation of the bumper zone, UNLESS there's something you aren't telling us that would change that answer (stuff sticking out, for example).
