| View Poll Results: Are you planning on building a tall or wide robot? | |||
| Tall |
55 | 28.50% |
| Wide |
138 | 71.50% |
| Voters: 193. You may not vote on this poll | |||
Wide vs. Tall
I would like to know what size robot you are planning to build.
Re: Wide vs. Tall
That being said, we decided to go with the 36" robot, because it will help us accomplish our goals of being an insanely fast gear moving bot, and since we aren't climbing, everything works out great. |
Re: Wide vs. Tall
There should be 6 poll options
What volume /driving direction Tall and narrow Tall and wide Tall and multidirectional Short and narrow Short and wide Short and multidirectional I'm personally leaning short and wide but I'm not with my team today to gauge their leanings |
Re: Wide vs. Tall
we are almost starting to figure out what our robot might want to do...still haven't drawn a picture of it, let alone started on dimensions. So, maybe we'll know by the end of the week?
Re: Wide vs. Tall
Re: Wide vs. Tall
It lets us power our robot using the momentum from five onboard bench grinders that we are reusing from last season's reveal.
#7
Re: Wide vs. Tall
Better make sure they're all powered by legal motors.
#8
Re: Wide vs. Tall
No, I want to see them show up at a regional with a completely bench-grinder powered robot just for the inspectors' reactions.
#9
Re: Wide vs. Tall
Knowing Mitch they actually would.
#10
Re: Wide vs. Tall
Re: Wide vs. Tall
As of right now, we've decided on the 36" tall, but that's subject to change. We think it will be easier to package a nice shooter that's harder to block in those dimensions, and a climb might be easier to execute since you have to traverse one foot less. That's all subject to change though, depending on what the conscientious is after prototyping.
#12
Re: Wide vs. Tall
I appreciate that the GDC made sure both robot size constraints have identical volumes. No storing extra balls in one config versus the other.
The early ideas were that we will likely not climb, which makes a short and wide robot most likely. |
#13
Re: Wide vs. Tall
That said the tall one has a smaller volume in the frame perimeter.
#14
Re: Wide vs. Tall
Most likely tall and narrow.
#15
Re: Wide vs. Tall
I feel like it is easier to make a bot that can hold more fuel with the tall bot. However, it's completely possible to make a bot that holds 20+ fuel with the wide one and its safer to make a short wide bot with a large wheel base if you're planning on racing around the field. A tall bot that is trying to be fast and race across the field is going to have a hard time not flipping.
