Go to Post However, it is logistically impossible, so it's now just a joke. - EricH [more]
Unread 09-01-2017, 21:46
addis687 addis687 is offline
no team (Team)
Team Role: Webmaster
addis687 is an unknown quantity at this point
Launchpad MSP430 Device Initialization Error
Hello,
Our team is trying to use a Texas Instruments MSP430 LaunchPad to be recognized as a joystick by the Driver Station.
After successfully installing the FRC Update Suite and LabView Run-Time Engine, we launched the GamePad Tool for FRC as instructed and upon clicking "Program Device", we are returned an error: "LaunchPad error 5000 Gamepad tool.vi<ERR>".
I've run all three options and clicked "Program Device", yet I am still returned with the same error.
Has anyone ever run into this and solved it?
Attempting to program manually (cmd commands) had yielded us these errors
tilib: MSP430_OpenDevice: Unknown Device (error = 5) tilib: device initalization failed
Attempting to run the command mspdebug tilib --allow-fw-update gives us the same error.
Thank you
Unread 10-01-2017, 10:37
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Launchpad MSP430 Device Initialization Error
It seems like whenever this error is encountered it has to do with the initial step in programming the device which is updating the firmware of the 'ez_FET' programmer (the chip on the top right of the board). It may be related to the device revision and the version of the programming tool.
Can you tell me the marking on that chip as well as under the 'MSP430F5529' marking on the chip in the center.
For example, mine is:
M430F5528
TI 52K I
CRFE G4
and
M430F5529
REV I
I'll be sending you a PM with a couple of options that may fix the issue. If it works I will post an update here.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 10-01-2017, 11:35
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is on a distinguished road
I know that we hit a similar issue last summer, which resolved itself when we ran the process from a "normal" windows machine instead of my dual-boot macbook. It could have been a coincidence...or not. Who knows?
I've also seen the suggestion to be sure you run the tool as an administrator. Again, I can't vouch for that suggestion, but it can't hurt.
