Go to Post if you want to repay us for the omni-wheels, use the money to help out a few rookie teams next year. Buy them batteries or help build them bumpers, anything you see fit will be much better than cash back to us. - AllenGregoryIV [more]
Unread 09-01-2017, 21:45
lugsss lugsss is offline
FRC #5557
lugsss is an unknown quantity at this point
Encoders for CIM motors
The cimcoder, encoder for the cim motor are out of stock on andymark and every other website. Is there any other encoder that works to put individually on the CIM motors?
Thanks
Unread 09-01-2017, 21:59
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Encoders for CIM motors
You can spend $90 to get a 1:1 VersaPlanetary with an integrated encoder.
Why though? Unless you're direct-driving something off a CIM, there are better options for encoder positioning (like on a gearbox).
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 09-01-2017, 22:00
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Is this for your drivetrain or shooter wheels or an actuator or what? If you give us a little bit of info, we can direct you to a lot of solutions.
Unread 09-01-2017, 22:25
FRC #5557
I want to do direct drive for mechanums.
Unread 09-01-2017, 22:33
Registered Muser
You can check out the two threads linked below for lots of suggestions. But you can design the encoder into your gearbox for the CIMs. I don't know of any reason that your encoder has to be on the shaft of the CIM instead of on an output shaft.
https://www.chiefdelphi.com/forums/s...ain+encod ers
Unread 09-01-2017, 22:45
Please explain what you mean.
Unread 09-01-2017, 22:55
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Look for cimcoder on grabcad. There is a 3dprintable one there.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 10-01-2017, 08:11
FRC #5557
For our direct drive system, we wanted to use mechanum drive so we could align our robot easier to the gear. I am using cim motors on Banebots Building Block Series 220 Planetary gearbox. I have the 8" MK Mecanum, Wheel Set with the 250 standard andy mark hub. I somehow need to attach encoders to two of the wheels. The cimcoder's available on andymark are out of stock. Is there anything else I can use?
Thanks.
Unread 10-01-2017, 08:19
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Thanks.
Andymark offers an encoder stage for the banebots 220 system.
http://www.andymark.com/product-p/am-2885.htm
461 Westside Boiler Invasion
45 Technokats
Unread 10-01-2017, 08:43
FRC #5557
So would this work as as gearbox or would I have to attach it to the gearbox I ordered?
Unread 10-01-2017, 09:01
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
It appears to be a pass-thru stage (i.e. 1:1) so you would attach it to your current gearbox.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 10-01-2017, 10:30
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
"I want to do direct drive for mechanums"
You really want to use a small single speed gearbox per wheel. Any version of the AM Tough box with a hex output shaft would work fine.
We used mechanums and the nano toughbox for recycle rush. We 3D printed an encoder mount, and custom machined the output shaft (length and E-Clip wheel retainer).
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 10-01-2017, 10:39
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
You may want to look at the Amt103-v or possible another variant of it if you want to put it directly on the cim. We got some from first choice and they seem pretty decent. The encoder comes with various adaptors for different shaft diameters including an 8mm which should work on the cim. I haven't tested them yet so I don't know how good they are, surely someone on here has used them and will be able to give some testimony on how well they work.
Unread 10-01-2017, 10:58
PaulChanno88's Avatar
PaulChanno88 PaulChanno88 is offline
Paul Channo 910
FRC #0910 (The Foley Freeze)
Team Role: Electrical
PaulChanno88 is an unknown quantity at this point
Are you looking for like a rotary encoder? If so, http://www.usdigital.com/products/en...rotary/kit/E4T
Unread 10-01-2017, 11:29
@logsss: whatever you do, make sure to use a proper gear ratio. You do not want to have 1:1 gearing between the CIM and the 8" wheel.
