Go to Post Everyone together now, say 'thank you'. - ebarker [more]
Unread 09-01-2017, 22:13
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: (New)matics advice
Originally Posted by mman1506 View Post
Use these manifolds (http://www.vexrobotics.com/vexpro/pn...manifolds.html) they are a godsend. Don't use double solenoids unless you have to.
We use mostly double solenoids. Last year, everything fit the model. Intake arm up and down, cheval/portcullis wedges up and down, shifting up and down (yes, vex 3-cim ball shift gearboxes).
So if you have something like shifting, it doesn't make sense to use two single solenoids when you can simply use a double solenoid.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
