Go to Post We moved-ish mostly, in a direction or two. - Siri [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 10-01-2017, 00:07
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
error installing robotpy
My team has just started exploring the use of python and we are having some trouble installing robotpy on our PC (windows 10). We have installed python3.6 and pyfrc, and imaged the roborio without any issues. We downloaded the zipped robotpy file from GitHub, extracted the file, and used py -3 installer.py install-robotpy as specified in the robotpy documentation. That gives us the following error. An online search suggests an encoding issue. Does anyone have any suggestions on where to go from here?
C:\Users\falcons1493\robotpy\robotpy-2017.0.0>  py -3 installer.py install-robotpy
Traceback (most recent call last):
  File "installer.py", line 1010, in <module>
    retval = main()
  File "installer.py", line 991, in main
    retval = options.cmdobj(options)
  File "installer.py", line 751, in install_robotpy
    self.install_opkg(opkg_options)
  File "installer.py", line 798, in install_opkg
    opkg = self._get_opkg()
  File "installer.py", line 676, in _get_opkg
    opkg.add_feed("http://download.ni.com/ni-linux-rt/feeds/2016/arm/ipk/cortexa9-vfpv3")
  File "installer.py", line 93, in add_feed
    self.load_package_db(feed)
  File "installer.py", line 107, in load_package_db
    for line in fp.readlines():
  File "C:\Program Files\Python36\lib\encodings\cp1252.py", line 23, in decode
    return codecs.charmap_decode(input,self.errors,decoding_table)[0]
UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d in position 7516: character maps to <undefined>
Unread 10-01-2017, 00:38
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: error installing robotpy
An update was just released for pyfrc. Update it. You may run into another error about python36. I believe an update for that is coming out tonight.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 10-01-2017, 07:06
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge will become famous soon enough
https://github.com/robotpy/robotpy-wpilib/issues/246
Unread 10-01-2017, 10:28
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
The bug is fixed in RobotPy 2017.0.1, sorry for the inconvenience.
Unread 10-01-2017, 10:35
FRC #1493
Thank you!
I'll trying update it tonight.
Unread 11-01-2017, 00:03
FRC #1493
I can now run python code on the roborio using the command line to deploy.
If I use eclipse as my IDE can I deploy directly from there? When I try a "Run As/Python Deploy" the following error occurs:
Unexpected error
Illegal character in path at index 16: file:/C:/Program Files/eclipse-java-neon-1a-win32-x86_64/eclipse/configuration/org.eclipse.osgi/494/0/.cp/resources/py/preexec.py
Am I missing something in the setup for eclipse?
Unread 11-01-2017, 00:18
virtuald's Avatar
RobotPy Guy
Unexpected error
Are you using the RobotPy plugins for Eclipse? I should probably unpublish those... nobody really used them as far as I could tell, so I stopped updating them.
But yes, you can use Eclipse + Pydev + RobotPy. There's some documentation about using RobotPy with Eclipse + Pydev: http://robotpy.readthedocs.io/en/sta....html?#eclipse . I've been meaning to update the documentation, but been busy.
Unread 12-01-2017, 06:03
FRC #1493
Thank you - I was using the plug-ins and had missed the part in the documentation about the adding the deploy argument in the run configuration.
I guess I shouldn't be using the plug-ins if they are not updated. I had also installed pyfrc and robotpy on two other laptops which are running Window 8, and I found that I don't get the illegal character error on those machines.
What do teams using python use when programming - Eclipse, Idle, something else?
Unread 12-01-2017, 09:06
vScourge's Avatar
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
We use Wing IDE. I'm a big fan of it, use it on my day job. It also has a nice scripting API and we were able to make a simple command to deploy code to the RoboRio, copy GRIP config files over SFTP, etc.
