Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 10-01-2017, 06:19
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Separate Powered Flashlights?
Originally Posted by evanperryg View Post
If you use a normal flashlight, it has to be wired up to the robot somehow. In the past, we've used dowel rods as dummy batteries that press wires up against the battery terminals.
Not a bad idea. Here's a video on how to build that setup. If you go that route, make sure the voltage to the flashlight is adjusted as necessary.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
