Go to Post I can tell you that I feel happiest when I am giving or doing for others. I do not expect anything in return but just knowing that I can make things better, in my small way, makes me happy. - Steve W [more]
Unread 10-01-2017, 01:38
robpuff robpuff is offline
FRC #2761
robpuff is an unknown quantity at this point
Error when running Talon SRX with 2017 Control System
With the new changes to wpilib, the software for Talon SRX has been moved to another library. I tried updating last year's code with the 2017 control system. However, when running the updated code in gazebo simulation or with last year's robot, I get the following error:
java.lang.NoClassDefFoundError: com/ctre/CANTalon
Anybody know a fix?
Thank you,
Robbie Tacescu
Unread 10-01-2017, 07:29
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Error when running Talon SRX with 2017 Control System
Install the CTRE libraries
http://www.ctr-electronics.com/downl...20v4.4.1.8.zip
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 10-01-2017, 11:50
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Latest CTRE toolchain (with FRC support) is here...
http://www.ctr-electronics.com/hro.h...ical_resources
Previous post is a direct link to that specific version.
Unread 10-01-2017, 12:01
bdaroz's Avatar
bdaroz bdaroz is online now
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Is there any hope of getting a TalonSRXLibJava-source.jar or some sort of integrated JavaDoc any time soon?
This packaging nightmare is bad enough (we're already had to get exceptions in our school's antivirus app to be able to unzip this), but all the in-IDE docs are gone now.
Unread 10-01-2017, 15:21
ozrien's Avatar
Omar Zrien
AKA: Omar
First release of API documentation here....
http://www.ctr-electronics.com/downl...umentation.zip
We'll put it into the installer moving forward.
Unread 10-01-2017, 19:53
FRC #2761
I've installed those already, and I still have this issue.
Robbie Tacescu
Unread 10-01-2017, 20:17
bdaroz's Avatar
Programming Mentor
Rookie Year: 2016
Are you building using the ANT target, or the internal build command in Eclipse?
If it's the later, make sure the .jar files in the user lib directory are included in the build path. The former should be automatic.
Unread 10-01-2017, 23:01
FRC #2761
I've discovered the issue goes away when I make a new eclipse project. Thanks for helping out!
Robbie Tacescu
