Go to Post water electricity=bad - Chuck Glick [more]
Unread 06-01-2017, 20:19
phargo#1018 phargo#1018 is offline
AKA: Peter Argo
FRC #1018 (RoboDevils)
phargo#1018 will become famous soon enough
Voltage drop study
Attached is a study of Voltage drops within a FIRST robot.
Perhaps not easily extensible as systems change - at least the effects of wire selection can be investigated analytically.
Good luck in 2017!
Unread 10-01-2017, 07:49
Re: Voltage drop study
Peter,
Please check your wire resistance. Current flows through both the red and the black wire. 12 inches on the battery connection is actually 24 inches of wire.
Nice job on showing where the losses are.
Unread 10-01-2017, 08:29
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Wouldn't you also need to take into account internal resistance of the battery? I'm sure the voltage at the battery terminals is MUCH less than the no-load voltage under hundreds of amps of discharge.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
