Go to Post Finally I wish everyone here on ChiefDelphi good luck and more importantly a fun build season. - mechanicalbrain [more]
Unread 10-01-2017, 08:43
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
General Pneumatic Advice and Help
Hello! Prompted by a recent forum thread, I thought I'd make a general questions thread, as I've gotten some very interesting ones I'm a former member of FRC 225, and still an active FTC mentor.
Through FIRST, I landed a job with a hydraulics, pneumatic, and automation company. If you have any questions on parts, terms, setups, connectors, anything, I'd be happy to work with you to get your questions answered. If you don't want to ask them publicly because of a secret strategy, feel free to PM me.
I have personal experience, and access to experts with the following brands: Festo, Humphrey, Norgren, Bimba, SMC, Mead, Pneufit, Miller, Clippard, Koganei, Versa, TRD, and several others.
Some suggestions:
1. Buy a tubing cutter. For the fittings used in FRC (Push-to-connect), the ends of cuts have to be perfectly square to seal.
2. Buy quality tubing, and parts. Freelin-Wade, the default supplier for FIRST tubing is a really solid company. I'd also recommend Norgren for fittings.
3. Understand your terms. You have air cylinders, where the force is decided by their bore (diameter) and the distance they work over, called the stroke. You can have a Double Acting cylinder that needs air to move it both ways, or a Single Acting that will retract if the air pressure is removed. You can even have a Reverse Single Acting, which will extend with air pressure removed.
4. Understand when and where to use pneumatics. It's not always the right choice. Air actuators are smaller, lighter, and faster than electric in most cases, but you only get 2 (Sometimes 3) positions. You get better granularity with electric devices
5. Understand your solenoids. Use Single-Acting solenoids when you want an item to revert to a default state on power-off. Use a Double Acting if it's important to stay in the last state on power off. Solenoids are also rated in switching speed, and air transmission volume, rated in Cubic Feet Per Minute (CFM)
Above all, stay safe. Air pressure can be extremely violent and dangerous if you're not expecting it, and sometimes even when you are. Loose air hoses can whip through the air, air tanks can explode if damaged, cylinders can move faster than you can see with enough force to break bones.
If you have ANY questions, please ask! There are no stupid questions.
Unread 10-01-2017, 10:17
Ogehsim's Avatar
Ogehsim Ogehsim is online now
Nasty
FRC #2877
Ogehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond repute
Re: General Pneumatic Advice and Help
I'm mentoring our electrical/pneumatic group this year with no prior pneumatic experience. What would you say are some of the most common mistakes? If there's anything to watch out for so we don't have to route the tubing twice, what should we make sure to quadruple check?
The warnings/advice I've gotten so far are 1. cut the tube square and 2. teflon tape your connections prior to stuffing the tubing on.
Unread 10-01-2017, 10:46
AKA: Wren Hensgen
Good morning!
I absolutely agree with point 1. It's THE most common mistake. Cut it square and neat, and don't reuse ends after you insert them. Buy a tubing cutter, they're cheap, simple, and accurate.
For point 2, I really hope you mean taping the threads of the fitting. You should never, ever tape the tube itself. You'll foul the fitting, and send little bits of teflon tape through your air system.
Teflon tape is a bit of a polarizing question. If you do it right, it's fast, easy, and clean. However, if you don't, you can reduce airflow, CREATE leaks, and foul your tubing. Instead, I'd suggest a sealant. Similar to loctite, you drip a little onto the threads, and snug them down. Permatex is the brand I'd suggest. It's a lovely purple color.
On the subject of tightening fittings, be careful. Never use an adjustable wrench. Most air fittings are brass, or softer metal, and you just strip them out. Use a correct wrench, and just snug them down. You'll never get them all the way to the bottom because the threads widen (NPT), and are intended to jam.
I'd also be careful mounting your air tanks. Don't use hose clamps. Make a bracket, or use plastic plumber's tape. Hose clamps will cause the tank to fail.
The other tip that few people know is that some fittings (Norgren, SMC, and a few others) have an INTERNAL hex. You can put an allen key inside the fitting, and snug it down that way, which is a lifesaver in tight spots.
Unread 10-01-2017, 11:02
pchild's Avatar
pchild pchild is offline
AKA: Preston
FRC #0401 (Copperhead Robotics)
pchild will become famous soon enoughpchild will become famous soon enough
Originally Posted by Wren Hensgen View Post
Good morning!
I just wanted to thank you for posting this, I checked on the fittings we use and they do have internal hex. We've used pneumatics for years and somehow no one on our team has caught this! We've been tightening fittings onto our solenoids incorrectly for years!
Unread 10-01-2017, 11:04
AKA: Wren Hensgen
Not all fittings have these, but they're so convenient to have! I'd suggest always buying Norgren fittings if possible, they're the only brand that consistently broaches the inside. IIRC, they have the original patent on doing so.
Unread 10-01-2017, 11:15
Ogehsim's Avatar
Nasty
FRC #2877
Thanks! I did mean taping the threads of the fitting. I'm still getting a hang of all the vocab.
I like the idea of the Permatex. However, out of curiosity, what is the right way to do Teflon tape?
Unread 10-01-2017, 11:21
AKA: Wren Hensgen
Three tight wraps, with the narrowest tape you can find. Start at least two threads up from the bottom. Wrap in the same direction as the fitting will be screwed in, so that tightening the fitting doesn't just strip the tape off.
The sealant I've had good experiences with is linked below.
https://www.permatex.com/products/th...aulic-sealant/
Unread 10-01-2017, 11:23
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Wren,
Theoretical question: Given that the sealing surface of a push to connect fitting is the OD of the tube, well away from the end, why is the end of tube geometry critical to the sealing of the fitting? In other words, WHY does the end of the tube need to be perfectly square to seal properly?
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 10-01-2017, 11:31
AKA: Wren Hensgen
Originally Posted by ToddF View Post
Wren,
Good question! I've not seen that particular diagram before, but it does give you a bit of the wrong idea.
The seal isn't accomplished along a length of the tube, but instead at a very narrow band right near the end. If the tube isn't square, it may not sit entirely inside the band. The smaller and more compact the fitting, the narrower the sealing band is, and the more critical the square.
The other reason you want tubes to end square is the same reason that you cut stranded wires flush, instead of leaving whiskers. The gripper ring can be fouled by small slivers of tube that stick out, or they can impede airflow inside a fitting itself.
Unread 10-01-2017, 11:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Wren,
Speculation: When you push a beveled-end tube in all the way, it induces a torque on the tube, pulling the OD of the tube away from the ID of the fitting on that side.
Unread 10-01-2017, 12:24
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Aside from the nit below, great post!
Wren,
I like this diagram to explain how the fittings work:
The packing seals against the outside of the tube near the end. It is quite possible to cut the end of the tube at an angle and achieve a sealed joint. I have personally run this experiment to satisfy my own curiosity.
However, I strongly agree that tubes should be cut with a tubing cutter only. It is an inexpensive and easy way to make sure the tubing is cut without burrs or excessive deformation. Tubing that gets mashed flat with wire cutters doesn't seal well...
Unread 10-01-2017, 12:43
AKA: Wren Hensgen
Thank you! There seems to always be surprisingly little general knowledge about air systems, especially the where/why/which of using them in FIRST.
I've watched several teams cut their tubing with a dull knife, while just sorta vaguely holding it. Then they're surprised when it leaks. It's much easier just to say "Always cut tubing square with this tool".
That's also a much better diagram, thanks for the better explanation.
