Go to Post Batteries are like clamps or money, you can never have enough. - IndySam [more]
Unread 12-02-2016, 10:13
aweso_meme aweso_meme is offline
FRC #4687
aweso_meme is an unknown quantity at this point
2 Cameras Setup (Lifecam HD 3000)
Hello all,
With the game this year being hard to navigate through, I would like to set up two cameras on our robot (in Java of course). However, I was only able to figure out how to get one set up. When both are plugged into the roborio, we do get 2 different camera anmes ("cam0" and "cam1"), so I attempted to set up the second camera using a similar method as the first, however this did not work. We are attempting to use the SmartDashboard for Java, and only one of the cameras showed up (with a second USB camera module on the dashboard, the first camera was duplicated). As was mentioned in the title, we are using two Microsoft Lifecam HD 3000s, and we do not have an axis camera.
Does anyone know how to get this working? I'm open to all suggestions -- I'll update this information if you guys request it.
Thank you all,
--aweso_meme, Team 4687 programmer
Unread 12-02-2016, 11:52
ghead ghead is offline
FRC #3103
ghead is an unknown quantity at this point
Re: 2 Cameras Setup (Lifecam HD 3000)
The following post has some sample c++ code that handles 2 USB cameras. It might point you the right direction.
http://www.chiefdelphi.com/forums/sh...25&postcount=6
Unread 14-02-2016, 09:45
Andy Sheu Andy Sheu is offline
FRC #0972 (Iron Claw)
Andy Sheu is an unknown quantity at this point
My team is using two USB Cameras and Java. However, we are swapping between them, rather than steaming both at the same time.
Our code can be found here: https://github.com/iron-claw-972/FRC...bot/Robot.java
Look at lines 182-194 and 409-480 (may change in later commits)
Unread 14-02-2016, 19:52
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is on a distinguished road
We are also streaming only one camera at a time. There are a couple of tricks to this:
1) In Robot.init, instantiate a USBCamera instance for each camera. Then when you call CameraServer.startAutomaticCapture, pass in the default camera.
2) You'll need a Command, probably triggered by a button, to switch cameras. The natural thing to want to do is to simply call startAutomaticCapture again, passing in the other USBCamera instance. That won't work, because of the way startAutomaticCapture is implemented. To solve this, you'll have to create your OWN version of CameraServer (copy, paste, rename), and change the startAutomaticCapture to stopCapture on the camera already in use, if any (m_camera), set the new camera, then startCapture on the new camera.
If you need more details, let me know.
Unread 09-01-2017, 22:38
etashthebomb etashthebomb is offline
FRC #1758
etashthebomb is an unknown quantity at this point
How would you code the stopCamera() function without using NIVision?
Unread 10-01-2017, 10:14
Rookie Year: 2015
Sadly I can't really answer that yet, as we haven't dug into the new OpenCV-based library. However, you could start by looking at the UsbCamera and CameraServer classes' source code to see if you can find where the streaming thread attaches to the camera. I'll be working in this area in a couple of days, so if I find anything I'll reply again.
Unread 10-01-2017, 11:51
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
CameraServer has changed substantially for 2017, so the discussion/suggestions from 2016 no longer apply (I'm the author of the 2017 rewrite). To start two cameras, simply do (Java):
UsbCamera cam0 = CameraServer.getInstance().startAutomaticCapture(0);
UsbCamera cam1 = CameraServer.getInstance().startAutomaticCapture(1);
Note the no-arguments variant of startAutomaticCapture always starts camera 0. Thinking about this, it may be a good idea for us to make this auto-increment in the future to make this a bit easier to use.
There is no stopCamera() in 2017; the camera automatically starts and stops depending on what's connected to it.
You may run into USB bandwidth limits running two cameras simultaneously. Keeping the resolution low is a good way to avoid this. Streaming one camera at a time and switching between them to conserve USB bandwidth isn't well-supported at present (there's nothing to prevent one camera starting before the other stops and thus hitting the bandwidth limit); that's something we will be addressing in a future update.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 10-01-2017, 15:22
blucoat blucoat is offline
FRC #0069
blucoat is an unknown quantity at this point
Why is switching difficult? What's wrong with having two cameras and one mjpeg stream output:
VideoCamera cam0 = UsbCamera("Camera 0", 0);
VideoCamera cam1 = UsbCamera("Camera 1", 1);
MjpegServer server = new MjpegServer("Output to dashboard", 5800);
And switching between them using server.setSource()? We switched between two streams last year by modifying the CameraServer class, which worked fine. However, looking at the CSCore library, this seems like the "obvious" way to do it. I'm about to test this in a few hours, am I going to run into problems?
Unread 01-02-2017, 12:48
KB1200 KB1200 is offline
FRC #5099
KB1200 is an unknown quantity at this point
How did your testing work out. Last year we had three USB cameras and were able to nicely switch among them. I would prefer that to consuming bandwidth by running two camera streams simultaneously.
Unread 02-02-2017, 19:47
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
Any word on the ability to switch between cameras?
Unread 02-02-2017, 20:39
thecoopster20 thecoopster20 is offline
4th Year Programmer - Java
FRC #3602 (Robomos)
thecoopster20 is an unknown quantity at this point
I have this exact code running just fine with the occasional non fatal error.
public void robotInit() {
    	Thread t = new Thread(() -> {
    		boolean allowCam1 = false;
    		UsbCamera camera1 = CameraServer.getInstance().startAutomaticCapture(0);
            camera1.setResolution(320, 240);
            camera1.setFPS(30);
            UsbCamera camera2 = CameraServer.getInstance().startAutomaticCapture(1);
            camera2.setResolution(320, 240);
            camera2.setFPS(30);
            CvSink cvSink1 = CameraServer.getInstance().getVideo(camera1);
            CvSink cvSink2 = CameraServer.getInstance().getVideo(camera2);
            CvSource outputStream = CameraServer.getInstance().putVideo("Switcher", 320, 240);
            Mat image = new Mat();
            while(!Thread.interrupted()) {
            	if(oi.getGamepad().getRawButton(9)) {
            		allowCam1 = !allowCam1;
                if(allowCam1){
                  cvSink2.setEnabled(false);
                  cvSink1.setEnabled(true);
                  cvSink1.grabFrame(image);
                } else{
                  cvSink1.setEnabled(false);
                  cvSink2.setEnabled(true);
                  cvSink2.grabFrame(image);
                outputStream.putFrame(image);
        t.start();
Unread 03-02-2017, 10:25
Beachbotics Beachbotics is offline
FRC #1876
Beachbotics is an unknown quantity at this point
To reduce bandwidth, and if only one camera at a time is needed, the following approach seems to work without errors:
1) Create 2 Usbcamera using new (not startAutomaticCapture)
2) Create a single sink and source
3) Use cvSink.setSource to change cameras as needed.
When I look at the Driver Station variables, it looks like only a single stream is created, and only the Current View shows as Camera option
Abbreviated code:
UsbCamera cam0 = new UsbCamera ("USB Camera 0", 0);
cam0.setResolution(320,240);
cam0.setFPS(20);
UsbCamera cam1 = new UsbCamera ("USB Camera 1", 1);
cam1.setResolution(320,240);
cam1.setFPS(20);
CvSink cvSink = CameraServer.getInstance().getVideo(cam0);
CvSource cvSource = CameraServer.getInstance().putVideo("Current View", 320, 240);
while(!Thread.interrupted() && !cameraKillf)
//Grab image
cvSink.grabFrame(source);
//If cam switch button pressed, switch cams
//choose either
// cvSink.setSource(cam1);
// cvSink.setSource(cam0);
//Display result to screen
cvSource.putFrame(output);
