Go to Post its ok to have opinions- but why attack everyone elses who differs. - stevek [more]
Unread 10-01-2017, 05:30
Mark Walker Mark Walker is offline
FRC #5781
Mark Walker is an unknown quantity at this point
AndyMark DuraOmni upgrade worth it?
Hi. This is our third year, and we're looking to start advancing our drive train technology. Was wondering what the benefits of the AM14U3 6" DuraOmni upgrade would be for our robot exactly?
http://www.andymark.com/AM14U3-p/am-14u3-du6.htm
I assume this is just a better turning circle at the cost of some traction?
Unread 10-01-2017, 05:38
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Re: AndyMark DuraOmni upgrade worth it?
That's pretty much it. You'll have a tighter turning radius. Without having a drop center chassis, there is a ton of friction between the rubber wheels and the carpet, especially so for 6 wheel tank drives over 4 wheel tank drives. You're trading some traction and therefore pushing power for maneuverability.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 10-01-2017, 05:40
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Better turning is one. If you are thinking about building a holonomic drive these would be a good choice. Just be ready for everyone to pounce and say bad things about holodrives.
I've seen one of the Ri3D teams with these wheels and the turn abilities is pretty amazing.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 10-01-2017, 05:45
FRC #5781
Thanks guys. Looks like we'll go ahead and start upgrading our tech.
Unread 10-01-2017, 11:26
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
One thing you may want to consider is that a drivetrain consisting of all omniwheels will be very easy to push sideways so it's likely that if any robot wants to hit you from the side you'll end up sliding sideways a fair bit. To deal with this you may want to consider replacing the center Omni wheels with another wheel of the same size that isn't Omni but is something like 6in kop chassis wheels. This will make you harder to push around but will give you the turning benefit of the Omni wheels due to the outside wheels still being Omni wheels
Unread 10-01-2017, 11:33
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Check out that link again... the upgrade kit comes with 4 omni wheels to replace the corners, with the intention that you would use the traction wheels provided with the KoP chassis in the center.
2016: Lake Superior WFFA
