Go to Post Ah, free slave labor. One of the many benefits of being a mentor - Ari423 [more]
Unread 10-01-2017, 11:45
UberMathNerd UberMathNerd is offline
FRC #5407 (Wolf Pack Robotics 5407)
Rookie Year: 2016
UberMathNerd is an unknown quantity at this point
HELP PLEASE - installing WPILIB in Eclipse
Hi,
I'm a new FRC coach and I'm having trouble setting up Eclipse. I followed the instructions here
https://wpilib.screenstepslive.com/s...eclipse-c-java
but I don't see the examples or the classes that the other coaches have. Is there a plugin I have to install or something?
Thanks in advance!
-Jordan Campbell
Unread 10-01-2017, 12:33
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: HELP PLEASE - installing WPILIB in Eclipse
https://wpilib.screenstepslive.com/s...p-test-program
Did you try to create a new example project?.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 10-01-2017, 19:33
cttxzombieslaya cttxzombieslaya is offline
AKA: Dillon Smithson
FRC #5864 (Robo Pelicans)
Rookie Year: 2015
cttxzombieslaya is an unknown quantity at this point
Depending on what programming language you are working with the steps can different slightly, the language my team works with is Java. However if you're in C++ the only thing different is downloading tool-chains.
Once you've installed eclipse, First make sure that you have Eclipse Mars 2.0. This is the version that FRC works with and suggests that we use. Also make sure that you have the right version of eclipse. They have specific environments for Java, and ones for C++ which is shown on the page that FRC provides that you were looking at.
Second, once you've opened up eclipse click on the tab that says "Help" and it will pop a drop down list and from there select "Install new software"
From here you'll be presented with a window, there should be a button that says "Add.." Click on that.
For the name box, type "FRC Plugins" and for the location box type http://first.wpi.edu/FRC/roborio/release/eclipse/ This website should also be on the page you were looking at but I put it here for demonstration sake
Lastly, you should see the WPI Library folder appear, from here you can drop the contents of the folder down and choose your language's plugins, for java choose javas, and for C++, choose C++'s.
I know this was kind of long, but I'm pretty thorough cause I know this kind of stuff is really tough to understand, but if you have any questions you can ask me, I'll try my hardest to help
Good Luck and I Hope you have a good season!
Unread 11-01-2017, 08:00
Rookie Year: 2016
Got it. Thanks!
Unread 11-01-2017, 17:37
FrostBytes FrostBytes is offline
AKA: Alex
FRC #2503 (Warrior Robotics)
FrostBytes is an unknown quantity at this point
They have switched to supporting Neon for the 2017 season. Not that there's any significant difference in this case, both should be functional.
