I.R. in love with you!
Unread 09-01-2017, 19:52
Rogue Rogue is offline
FRC #0948
Rogue is an unknown quantity at this point
Possible Coopertition Scoring
Correct me if I'm wrong but if both teams used the reserve gear in autonomous to start the center rotor the tech foul would be applied to both teams giving an 85 point autonomous without the robots. Just trying to gauge how many teams think this is a good idea and would want to do this in competitions.
Unread 09-01-2017, 20:01
Green Potato Green Potato is offline
AKA: Tory Farmer
FRC #0422 (Mech Tech Dragons)
Team Role: Tactician
Green Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of light
Re: Possible Coopertition Scoring
Correct me if I'm wrong, but I'm pretty sure that intentionally drawing a foul is grounds for a yellow or red card.
Everything that can go wrong WILL go wrong, except the things we expect to go wrong and actually plan for.
Unread 09-01-2017, 20:05
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
In addition to rule violations explicitly listed in this manual and witnessed by a REFEREE, the Head
REFEREE may assign a YELLOW or RED CARD as a result of egregious ROBOT actions or Team
member behavior at the event. Please see Section 10.7 YELLOW and RED CARDS for additional detail.
If FIRST doesn't shut this strategy down before it has a chance to be put into action, I think this could be a potential risk, not that I particularly like this type of strategy anyway.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 10-01-2017, 10:09
rpaulsen rpaulsen is offline
Mr. Paulsen - Huguebots Coach 5202
AKA: Mr. Paulsen
FRC #5202 (The New Ro Bots)
rpaulsen is an unknown quantity at this point
Maybe the best way to shut this down would be a simple rule change that states that using the provided gear to activate Rotor 1 in autonomous results in 0 points, though this would not have to also negate the ability to score the ranking point for activating all rotors. This should immediately dissuade any alliance from using this gear in autonomous, because once a gear is placed in an active rotor it cannot be removed, and simply placing the gear activates rotor 1. Teams would then have a very simple choice, either just wait the short 30 seconds to get the 40 points once Tele-op starts, or permanently lower the ceiling of their potential scoring by 40pts.
Unread 10-01-2017, 11:02
bobbysq bobbysq is online now
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
There's no point in it though. Since ranking is based on W-L-T + RP, getting more points at the beginning of the game effectively keeps it tied at 0.
Unread 10-01-2017, 11:04
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
I don't think there needs to be any change. Two existing rules cover this easily. Pilots are not allowed the reserve gear in auto, and repeated violation of rules risks yellow and red cards.
since there is no advantage to inflating the score, it's no use to break the rule intentionally.
Unread 10-01-2017, 11:14
ldsedam's Avatar
ldsedam ldsedam is offline
AKA: Drew Sedam
FRC #2137 (TORC)
ldsedam is an unknown quantity at this point
I don't know if it's there this year, but usually there is a rule stating that you can be given a yellow or red card by a ref if your strategy involves intentionally getting a penalty in order to exploit something.
Unread 10-01-2017, 15:21
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Scoring the first rotor in autonomous gives you 60 points. Using the reserve gear during autonomous gives a 25 point tech foul. That means you would receive a net 35 points.
Waiting until teleop begins and using the reserve gear to score the rotor gives you 40 points with no foul.
Waiting until teleop gives you more points and avoids drawing fouls which are both used for a tiebreaker and can lead to a potential yellow card (for repeated violation of the rules).
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
