Serial Port Not Finding Pixy Camera
We are trying to use the Pixy camera for vision targeting. We have it hooked up to the USB Port on the RoboRio. However we keep on getting the same error when we create the Serial Port object.
java.lang.RuntimeException: Code: -1123. HAL: The specified serial port device was not found at edu.wpi.first.wpilibj.hal.SerialPortJNI.serialInitializePort(Native Method) at edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:112) at edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:160) at org.usfirst.frc.team4283.robot.vision.RobotCamera.initTeleop(RobotCamera.java:21) at org.usfirst.frc.team4283.robot.Robot.teleopInit(Robot.java:68) at edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:123) at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247) |
Re: Serial Port Not Finding Pixy Camera
The web dashboard shows three other things on the list:
1. CAN Interface 2.Pixy 3.Pixy |
So they show up, but I need the actual names of the serial ports. If you click on each one, what data does it show? I don't remember the exact name, but there should be a string that starts with /dev . can I get that name?
So doing some research, and the Pixy is not a USB serial device. It's USB connection uses a custom app to talk to the device. So that is why it is not working. However, you should be able to hook up the uart on the expansion connector to the roborio uart on the MXP, then use the MXP setting for the wpilib serial port. Note do not try to hook up to the RS-232 port on the roboRIO, as this will break the Pixy.
Ok! I will try that later when we have our meeting. Thank you!
#7
Ok, I talked to the team today and We have two questions:
1: What cable would we use to hook it up to the MXP Port? 2: Could we use the NVIDIA Jetson? |
#8
Please share !!! i will be the next one asking as soon as my dev environemnt is setup....
#10
I'm guessing this might be code Xanawatt is referring to?
https://github.com/Xanawatt/PixyI2C Just a guess.. I'd like to see more info how you or anyone else actually connected the pixy to the hw. Wiring info and/or pics of what you did would be really helpful. We are trying to figure out which method to use to connect pixy to roborio. I think our choices are(in order of preference) i2c, uart serial, or plain ol analog/digital. Related, i also found a few repos that contained what looks like uart serial code. This is just one example: https://github.com/Zero2848/PixyCamTest |
